Introducción
Keep processor temperatures down by replacing your broken fans.
Lay the iMac display-side down on a flat surface.
  • Lay the iMac display-side down on a flat surface.
  • Loosen the three Phillips screws securing the rear panel to the iMac.
  • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
My iMac has only ONE catch, the central one, so the two outer screws are not to be touched.
In fact, I tried so hard to unscrew them, with a good screwdriver, that my hand hurt. Knowing that some times captive things (like these screws or a faucet) can be already at the end of their travel and we only lock them further into that position, I tried both screwing and unscrewing to no avail.
paulfrancoeur - Contestar
That chick MJ is sexy!!!!!
djmadcracker - Contestar
Looks like one of these screws is not like the others... a security Philips?! Never seen one of those before.
Terry Mullane - Contestar
Please Note: If your iMac has an antenna for the airport extreme and not the bluetooth card. Don't buy the bluetooth get the airport extreme instead. Also, some newer devices may not work with these units.
James Janota - Contestar
Just want to say thank you to ifixit! You guys are amazing and so helpful! This was so easy to do and I ordered the part I needed as well! We are up and running over here and my 7 year old son could not be any happier! Thank you!
mary nicolazzo - Contestar
Lift the rear panel slightly from the bottom edge of the iMac. Pull the rear panel toward yourself and remove it from the iMac. Pull the rear panel toward yourself and remove it from the iMac.
  • Lift the rear panel slightly from the bottom edge of the iMac.
  • Pull the rear panel toward yourself and remove it from the iMac.
Agregar Comentario
Remove the two Phillips screws securing the fan cover to the midplane. The shouldered screw belongs in the lower left corner of the fan cover.
  • Remove the two Phillips screws securing the fan cover to the midplane.
  • The shouldered screw belongs in the lower left corner of the fan cover.
  • Lift the fan cover up off midplane.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Disconnect the hard drive data cable connector from the logic board by pulling its connector straight up.
  • Disconnect the hard drive data cable connector from the logic board by pulling its connector straight up.
Agregar Comentario
Disconnect the upper left fan cable connector from the logic board by pulling its connector straight up.
  • Disconnect the upper left fan cable connector from the logic board by pulling its connector straight up.
Agregar Comentario
De-route the fan cable from around the edge of the logic board as necessary.
  • De-route the fan cable from around the edge of the logic board as necessary.
Agregar Comentario
Remove the two T8 Torx screws securing the upper left fan to the chassis. Lift the upper left fan out of the chassis.
  • Remove the two T8 Torx screws securing the upper left fan to the chassis.
  • Lift the upper left fan out of the chassis.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 7
Todo El Tiempo: 7,248
