Saltar al contenido principal
iMac G5 17" Model A1058 Rear Panel Replacement
Qué necesitas
  1. iMac G5 17" Model A1058 Rear Panel Replacement, Rear Panel: paso 1, imagen 1 de 1
    • Lay the iMac display-side down on a flat surface.
    • Loosen the three Phillips screws securing the rear panel to the iMac.
    • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
  2. iMac G5 17" Model A1058 Rear Panel Replacement: paso 2, imagen 1 de 3 iMac G5 17" Model A1058 Rear Panel Replacement: paso 2, imagen 2 de 3 iMac G5 17" Model A1058 Rear Panel Replacement: paso 2, imagen 3 de 3
    • Lift the rear panel slightly from the bottom edge of the iMac.
    • Pull the rear panel toward yourself and remove it from the iMac.
Conclusión
15 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 11,149
