Saltar al contenido principal
iMac G5 17" Model A1058 Inverter Replacement
Qué necesitas
  1. iMac G5 17" Model A1058 Inverter Replacement, Rear Panel: paso 1, imagen 1 de 1
    • Lay the iMac display-side down on a flat surface.
    • Loosen the three Phillips screws securing the rear panel to the iMac.
    • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
  2. iMac G5 17" Model A1058 Inverter Replacement: paso 2, imagen 1 de 3 iMac G5 17" Model A1058 Inverter Replacement: paso 2, imagen 2 de 3 iMac G5 17" Model A1058 Inverter Replacement: paso 2, imagen 3 de 3
    • Lift the rear panel slightly from the bottom edge of the iMac.
    • Pull the rear panel toward yourself and remove it from the iMac.
  3. iMac G5 17" Model A1058 Inverter Replacement, Optical Drive: paso 3, imagen 1 de 1
    • Remove the three 8 mm brass Phillips screws securing the optical drive to the midplane.
  4. iMac G5 17" Model A1058 Inverter Replacement: paso 4, imagen 1 de 3 iMac G5 17" Model A1058 Inverter Replacement: paso 4, imagen 2 de 3 iMac G5 17" Model A1058 Inverter Replacement: paso 4, imagen 3 de 3
    • Lift the optical drive near the connector to separate it from the logic board.
    • Lift the free end of the optical drive just enough to clear the fan cover. Lifting the free end of the optical drive too far may break the plastic positioning pins off the front bezel.
    • Lift the free end of the optical drive slightly, then pull it away from the edge of the rear case to clear the two plastic positioning pins.
    • Lift the optical drive out of your iMac.
    • When reinstalling your optical drive it may be necessary to set the bezel attached to the open end of the drive on the plastic positioning pins molded into the front bezel of the iMac and pull the connector side of the drive toward the edge of the rear case, bending it outward slightly, to properly seat the connector.
  5. iMac G5 17" Model A1058 Inverter Replacement, Inverter: paso 5, imagen 1 de 1
    • Slide the inverter-to-display cable connector from under the metal clip on the midplane.
  6. iMac G5 17" Model A1058 Inverter Replacement: paso 6, imagen 1 de 1
    • Disconnect the inverter-to-display cable connector by pulling it straight away from its socket.
  7. iMac G5 17" Model A1058 Inverter Replacement: paso 7, imagen 1 de 2 iMac G5 17" Model A1058 Inverter Replacement: paso 7, imagen 2 de 2
    • Remove the single Phillips screw securing the inverter to the logic board.
    • Lift the inverter straight up off the pins on the logic board.
    • Be sure to lift the inverter straight up off the logic board, as the connector pins are very long and easily bent. If the pins bend during removal, use the connector on the inverter as a guide to bend them straight.
  8. iMac G5 17" Model A1058 Inverter Replacement: paso 8, imagen 1 de 1
    • De-route the inverter cable connector from the channel in the logic board.
  9. iMac G5 17" Model A1058 Inverter Replacement: paso 9, imagen 1 de 1
    • Disconnect the inverter cable from the logic board by pulling it straight up from its socket.
    • Replacement note: it may be helpful to carefully reattach this connector before seating the midplane assembly, making sure the connector safely passes through the hole in the midplane assembly.
  10. iMac G5 17" Model A1058 Inverter Replacement, Inverter: paso 10, imagen 1 de 2 iMac G5 17" Model A1058 Inverter Replacement, Inverter: paso 10, imagen 2 de 2
    • Insert the flat end of a spudger between the plastic inverter cover and the inverter board.
    • Run the spudger along the edge of the inverter board to free all the tabs holding the plastic inverter cover to the inverter board.
  11. iMac G5 17" Model A1058 Inverter Replacement: paso 11, imagen 1 de 1
    • Lift the plastic inverter cover off the inverter board.
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 14
Ultimos 30 días: 34
Todo El Tiempo: 11,218
