Introducción
Remove all electrical wires from the computer, and lay the computer flat on its screen. The computer should rest on a smooth, padded surface.
Qué necesitas
Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
Remove the 2 torx 10mm screws on the EMI shield
Carefully remove shield and copper tape
Peel back the white paper, revealing the screws that connect the hard drive to the carrier.
Remove the 4 T-10 5mm screws connecting the hard drive and frame. (There are 2 screws on each side)
Before you reassemble the computer, double check that your new hard drive has the same jumper configuration as the old one. This ensures the IDE "Master-Slave" protocol isn't interrupted. Some systems do not require this, but if you are having issues booting up afterwards with the storage or the disc drive, this could be the source of the problem.
Take out the two T-15 screws that hold the fan brackets to the chassis.
Remove the four T-20 screws that hold the brackets onto the fan itself.
Now you can remove the fan from the computer. There may be an adhesive seal holding the fan to the chassis, so some force may be required.
6 personas más completaron esta guía.
6 comentarios
I don't see why it would be necessary... ??
anyone have a link for an adapter i can use to make any regular pc fan work in the imac g4? i was looking at a blue LED one on amazon and a guy said in the comments it would work but it needed an adapter but I can’t seem to find the correct one! plz help, thanks!
What size is the fan? Regular 3 pin connector?
