Saltar al contenido principal
iMac G4 15" 700 MHz EMC 1873 AirPort Card Replacement
Qué necesitas
  1. iMac G4 15" 700 MHz EMC 1873 AirPort Card Replacement, Outer Base Plate: paso 1, imagen 1 de 2 iMac G4 15" 700 MHz EMC 1873 AirPort Card Replacement, Outer Base Plate: paso 1, imagen 2 de 2
    • Place the computer monitor face down on a safe, harmless surface.
    • Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
  2. iMac G4 15" 700 MHz EMC 1873 AirPort Card Replacement: paso 2, imagen 1 de 1
    • Remove the metal plate from bottom of the iMac G4.
    • The four screws do not completely separate from the metal plate.
  3. iMac G4 15" 700 MHz EMC 1873 AirPort Card Replacement, AirPort Card: paso 3, imagen 1 de 1
    • Use a spudger to lift and remove the AirPort's antenna connector.
    • This step is only applicable to iMacs that came with an AirPort card installed.
Conclusión
14 personas más completaron esta guía.
Lilly
Miembro Desde 10/11/11
632 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 5-32, Amido Fall 2011 Miembro de Cal Poly, Team 5-32, Amido Fall 2011
CPSU-AMIDO-F11S5G32
4 Miembros
8 Guías creadas
3 comentarios
Make sure to insert the AirPort Card with the label facing down, away from you.
Nathan Larsen - Contestar
Does the antennae cable not plug into the card - Your illustration shows a large cable simply taped on top of the card and, as far as I can see, a smaller thinner cable that appears to be going to the card. I have the bigger cable in my iMac but it dues not appear to fit into the card - Do Inhave the wrong card or something?
roger - Contestar
The big cable plugs into the card. The little cable is a drawing on the iMac to show you how the cable should go. You are right, Step 3 does show the cable on top of the card, not plugged into it.
Dave -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 27
Todo El Tiempo: 8,494
