Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
iMac G3 Model M4984 RAM Replacement
Qué necesitas
  1. iMac G3 Model M4984 RAM Replacement, Logic Board: paso 1, imagen 1 de 1
    • The iMac G3. This was a great computer for the time, and had plenty of features.
  2. iMac G3 Model M4984 RAM Replacement: paso 2, imagen 1 de 1
    • Start by flipping the iMac upside-down. It may help to lay it on a towel, so you don't damage the screen, or scratch the face.
  3. iMac G3 Model M4984 RAM Replacement: paso 3, imagen 1 de 3 iMac G3 Model M4984 RAM Replacement: paso 3, imagen 2 de 3 iMac G3 Model M4984 RAM Replacement: paso 3, imagen 3 de 3
    • Remove this Phillips screw.
    • Using a flathead screwdriver, work your way around the bottom cover, until it comes off.
    • Then, lift the bottom cover up and out, and set it aside.
  4. iMac G3 Model M4984 RAM Replacement: paso 4, imagen 1 de 3 iMac G3 Model M4984 RAM Replacement: paso 4, imagen 2 de 3 iMac G3 Model M4984 RAM Replacement: paso 4, imagen 3 de 3
    • Now, remove the DB-15 Video connector from the logic board.
    • It may be helpful to use a Phillips screwdriver to remove the thumbscrews.
  5. iMac G3 Model M4984 RAM Replacement: paso 5, imagen 1 de 3 iMac G3 Model M4984 RAM Replacement: paso 5, imagen 2 de 3 iMac G3 Model M4984 RAM Replacement: paso 5, imagen 3 de 3
    • Remove the power cable from the logic board assembly.
  6. iMac G3 Model M4984 RAM Replacement: paso 6, imagen 1 de 2 iMac G3 Model M4984 RAM Replacement: paso 6, imagen 2 de 2
    • Remove the front panel connector. (You may also need to remove an additional screw that connects the front panel connector to the logic board assembly).
  7. iMac G3 Model M4984 RAM Replacement: paso 7, imagen 1 de 3 iMac G3 Model M4984 RAM Replacement: paso 7, imagen 2 de 3 iMac G3 Model M4984 RAM Replacement: paso 7, imagen 3 de 3
    • Now, remove these Phillips screws.
    • Now, grab the logic board assembly by the piece of plastic, and lift it out.
  8. iMac G3 Model M4984 RAM Replacement: paso 8, imagen 1 de 1
    • The logic board assembly. This is the heart of the computer, it contains the motherboard, CPU, RAM, V-RAM, PRAM battery, the hard drive, and the optical drive.
  9. iMac G3 Model M4984 RAM Replacement, RAM: paso 9, imagen 1 de 1
    • Now, it's time to remove the RAM.
  10. iMac G3 Model M4984 RAM Replacement: paso 10, imagen 1 de 3 iMac G3 Model M4984 RAM Replacement: paso 10, imagen 2 de 3 iMac G3 Model M4984 RAM Replacement: paso 10, imagen 3 de 3
    • Remove the CPU shield, this will reveal the "top slot". This is the user-serviceable RAM slot, though there is a a second slot of RAM under the CPU card.
    • The iMac uses PC100 Laptop Ram, and according to Apple, it supports up to 256MB RAM (2X128MB) but unofficially. Some later models can support 512MB (2X256MB).
    • Push the tabs out, and the RAM should pop up, then pull the ram out.
  11. iMac G3 Model M4984 RAM Replacement: paso 11, imagen 1 de 2 iMac G3 Model M4984 RAM Replacement: paso 11, imagen 2 de 2
    • RAM (bottom slot).
    • Remove the CPU Heatsink.
    • Use a flathead screwdriver. Remove the heatsink clip, it will pop off, and may get lost if you don't keep track of it.
    • Remove the heatsink revealing the CPU, then lift the CPU card up, and it should come free with a little tug.
  12. iMac G3 Model M4984 RAM Replacement: paso 12, imagen 1 de 3 iMac G3 Model M4984 RAM Replacement: paso 12, imagen 2 de 3 iMac G3 Model M4984 RAM Replacement: paso 12, imagen 3 de 3
    • Removing the CPU Card:
    • Lift the card out by this end!
  13. iMac G3 Model M4984 RAM Replacement: paso 13, imagen 1 de 3 iMac G3 Model M4984 RAM Replacement: paso 13, imagen 2 de 3 iMac G3 Model M4984 RAM Replacement: paso 13, imagen 3 de 3
    • Now, flip the card over.
    • This will reveal another stick of laptop PC66.
    • This is most likely a 32MB Stick, because the iMac shipped standard with only 32MB of RAM.
    • Now, remove it by pushing the tabs, it should pop up, and you can set it aside.
  14. iMac G3 Model M4984 RAM Replacement: paso 14, imagen 1 de 1
    • The RAM.
    • The iMac supports two pieces of PC66 laptop RAM, though it can use PC100 and PC133 (laptop size of course).
Conclusión
23 personas más completaron esta guía.
Chris Green
Miembro Desde 10/11/09
38,285 Reputación
49 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
Miembros de 333
1,479 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 28
Ultimos 30 días: 94
Todo El Tiempo: 24,009
