Introducción
The iHome IH27B is a portable alarm clock and sound system. This device acts as a dock for the following devices: iPhone 8, 9 and 10. Placing your iPod on and off of the adapter can cause some normal wear and tear to the dock connector. If you have noticed that your dock connector on the dock is loose or appears to be damaged, you may need to replace the iPod connector.
Qué necesitas
Set the IHome on a surface facing upward.
Locate the two screws on the docking station adapter.
Remove the following screws:
Two 10 mm Phillips #0
Una persona más ha completado esta guía.
