Partes
No se requieren partes.
Remove any iPod or apple music device connected to the iHome and unplug from any power source.
  • Remove any iPod or apple music device connected to the iHome and unplug from any power source.
  • Flip the iHome so the speakers are laying on a flat surface, and you have the concealed battery areas facing you.
Agregar Comentario
Using your fingers, press down firmly on the plastic slide and push in the direction of the arrows shown above the word "Open" on the plastic. Remove the plastic slide from its location and set it aside. These plastic slides are not interchangeable, so make sure each goes back to its original location in reassembly.
  • Using your fingers, press down firmly on the plastic slide and push in the direction of the arrows shown above the word "Open" on the plastic.
  • Remove the plastic slide from its location and set it aside.
  • These plastic slides are not interchangeable, so make sure each goes back to its original location in reassembly.
  • Remove all 4 AA batteries by placing your fingernail at one end of the battery and applying force upwards until the battery is freed from its holder.
  • Set the batteries aside, careful to not get them wet.
  • Insert your fingernail or a prying tool under the notch of the plastic slide that is protecting the watch battery.
  • Apply force in the direction of the arrow shown above the word "Open" on the plastic. The plastic piece covering the watch battery should come loose.
  • Set this plastic covering aside as well.
Agregar Comentario
Remove the following screws:
  • Remove the following screws:
    • Eight 10 mm Phillips #0
  • Cataloging each screw by size in plastic bags or separate places on a flat surface will make them easier to find when reassembling.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Use your fingers or a plastic opening tool to carefully pry apart the plastic connections still connecting the base to the top.
  • Use your fingers or a plastic opening tool to carefully pry apart the plastic connections still connecting the base to the top.
  • Be careful not to pry too hard. Cracking the plastic connections could make reassembly harder.
Agregar Comentario
Slowly lift the plastic base towards you and lay it on the flat surface. The base should still be connected to the rest of the iHome by a few wires.
  • Slowly lift the plastic base towards you and lay it on the flat surface. The base should still be connected to the rest of the iHome by a few wires.
  • You should have visible access to most of the components inside the iHome now.
Agregar Comentario
    • Two 10 mm Phillips #0
Agregar Comentario
Pull out the AV circuit board and lift it up and out of the way to allow access to other components.
  • Pull out the AV circuit board and lift it up and out of the way to allow access to other components.
Agregar Comentario
  • Pull the speakers away and set them aside for now. They should still be connected to the rest of the iHome by two wires.
Agregar Comentario
Remove the following 6 screws:
  • Remove the following 6 screws:
    • Two 7 mm Phillips #0
    • Three 10 mm Phillips #2
    • One 9 mm Phillips #2
  • Set the screws aside, careful to not mix them up with your other screws.
Agregar Comentario
Conclusión
John Kraemer
Miembro Desde 09/10/12
64 Reputación
9 Guías creadas
Equipo
Cal Poly, Team 3-21, Amido Fall 2012 Miembro de Cal Poly, Team 3-21, Amido Fall 2012
CPSU-AMIDO-F12S3G21
4 Miembros
9 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 681
