Introducción
Remove your rear display bezel to access your display's internals.
Lay your iBook upside down on a flat surface. Use a coin to rotate the battery locking screw 90 degrees clockwise.
  • Lay your iBook upside down on a flat surface.
  • Use a coin to rotate the battery locking screw 90 degrees clockwise.
  • Lift the battery out of the computer.
Agregar Comentario
Use a 1.5mm hex screwdriver to remove the two hex screws on either side of the display (four screws total). If you don't have a 1.5mm hex driver, you can probably get these screws out with a T6 Torx screwdriver. However, if you use a T6 Torx driver you'll be more likely to strip the screws.
  • Use a 1.5mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
  • If you don't have a 1.5mm hex driver, you can probably get these screws out with a T6 Torx screwdriver. However, if you use a T6 Torx driver you'll be more likely to strip the screws.
Agregar Comentario
Insert the flat end of a spudger perpendicular to the face of the display into the gap between the front and rear bezels near the upper left corner of the display. Rotate the spudger away from the display to pry the rear bezel off the front bezel.
  • Insert the flat end of a spudger perpendicular to the face of the display into the gap between the front and rear bezels near the upper left corner of the display.
  • Rotate the spudger away from the display to pry the rear bezel off the front bezel.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Run your spudger along the top edge of the front display bezel to evenly separate the two bezels.
  • Run your spudger along the top edge of the front display bezel to evenly separate the two bezels.
Agregar Comentario
Working down from the upper left corner, use the flat end of a spudger to pry the rear bezel away from the left edge of the display. Working down from the upper left corner, use the flat end of a spudger to pry the rear bezel away from the left edge of the display.
  • Working down from the upper left corner, use the flat end of a spudger to pry the rear bezel away from the left edge of the display.
Agregar Comentario
Use the flat end of a spudger to pry the rear bezel away from the right edge of the display.
  • Use the flat end of a spudger to pry the rear bezel away from the right edge of the display.
  • If necessary, pry along the bottom edge of the rear bezel to separate it from the display assembly.
Agregar Comentario
Lift the rear bezel off the display assembly.
  • Lift the rear bezel off the display assembly.
Agregar Comentario
Conclusión
3 personas más completaron esta guía.
Documentos Adjuntos
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 3,189
