Introducción
The motherboard includes all ports except the DC-In board.
Use a coin to turn both battery locking screws 90 degrees to the left.
  • Use a coin to turn both battery locking screws 90 degrees to the left.
  • Remove the battery cover.
  • Remove the battery from the computer by pulling up on the plastic tab.
Agregar Comentario
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free. Note that the keyboard ribbon is still attached to the logic board, so you cannot completely remove the keyboard yet.
  • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free. Note that the keyboard ribbon is still attached to the logic board, so you cannot completely remove the keyboard yet.
  • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw (between F4 and F5 key) 180 degrees in either direction and try again.
  • Rotate the keyboard away from the screen and rest it face-down on the trackpad area.
Agregar Comentario
If your computer does not have an airport card, you can skip the next two steps.
  • If your computer does not have an airport card, you can skip the next two steps.
  • Grasp the clear plastic tab on the airport card and pull up and toward the display.
Agregar Comentario
Hold the airport card in one hand and use your other hand to remove the antenna cable.
  • Hold the airport card in one hand and use your other hand to remove the antenna cable.
Agregar Comentario
Remove the two Phillips screws that secure the RAM shield.
  • Remove the two Phillips screws that secure the RAM shield.
Agregar Comentario
Grasp the wire metal bracket on top of the RAM shield and pull upward to remove the shield.
  • Grasp the wire metal bracket on top of the RAM shield and pull upward to remove the shield.
Agregar Comentario
Pull up the keyboard connector cable by its clear plastic loop.
  • Pull up the keyboard connector cable by its clear plastic loop.
Agregar Comentario
Use a straightened paperclip to manually eject the CD-ROM tray.
  • Use a straightened paperclip to manually eject the CD-ROM tray.
Agregar Comentario
Turn the computer over so that the bottom is facing up.
  • Turn the computer over so that the bottom is facing up.
  • Remove the following Torx screws:
    • Four short T8 Torx near the battery compartment.
    • Two long T8 Torx near the hinges.
Agregar Comentario
Pull the CD-ROM drive tray partly out.
  • Pull the CD-ROM drive tray partly out.
  • Remove the silver Phillips screw from the plastic casing.
Agregar Comentario
Turn the computer over.
  • Turn the computer over.
  • Remove the three Phillips screws.
Please note: these screws can (and may!) strip easily, so take extra care in removing them!
LambdaCalculus - Contestar
This is a diagram of the trackpad ribbon clamp connector you will disconnect in the next step.
  • This is a diagram of the trackpad ribbon clamp connector you will disconnect in the next step.
  • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
  • 2) After disengaging the locking bar, slide the cable out of the connector.
In part 1, you can use a small flat-blade screwdriver to lift the locking bar. This will not put pressure on the cable itself. Each end of the locking bar will click when it has been lifted sufficiently.
Don Solomon - Contestar
Loosen the trackpad clamp by pulling the top piece up slightly, freeing the trackpad ribbon.
  • Loosen the trackpad clamp by pulling the top piece up slightly, freeing the trackpad ribbon.
  • Slide the orange trackpad ribbon out of the clamp.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Do not lift the upper case too far without first disconnecting the audio cable.
  • Do not lift the upper case too far without first disconnecting the audio cable.
  • Push out the rim of the lower case and pull up on the upper case, grasping it just to the left of the optical drive.
  • Repeat the above step on the upper left corner of the upper case, grasping the bottom left corner of the upper case.
Agregar Comentario
Disconnect the audio cable.
  • Disconnect the audio cable.
Agregar Comentario
Grasp the upper case on either side of the keyboard space and rotate up and away from the screen.
  • Grasp the upper case on either side of the keyboard space and rotate up and away from the screen.
  • You may be thinking you're about to break your upper case. Not to worry - the tabs holding the upper and lower cases together are very strong. Simply apply even pressure and continue to rotate the upper case up and away from the screen until it comes free.
When replacing the upper case, test the trackpad button to make sure it clicks before proceeding. If it does not operate properly, remove the upper case and reattach it.
you can use a jimmy klive to open the uppercase
jimmyli564656 - Contestar
If the optical drive is not open, use a straightened paperclip to open it now.
  • If the optical drive is not open, use a straightened paperclip to open it now.
  • Remove the 5 mm standoff.
Agregar Comentario
Disconnect the optical drive cable from the logic board.
  • Disconnect the optical drive cable from the logic board.
Agregar Comentario
Lift up on the optical drive while sequentially pushing the small plastic tabs one after another toward the screen to free one side of the drive.
  • Lift up on the optical drive while sequentially pushing the small plastic tabs one after another toward the screen to free one side of the drive.
  • Lift up the side of the optical drive you just freed and slide the drive out and away from the screen.
  • When reinstalling the optical drive, be sure that the drive tray is out far enough to slide under the lower casing rim.
  • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
Agregar Comentario
Remove the following Phillips screws:
  • Remove the following Phillips screws:
    • Remove the longer Phillips screw from the middle-rear of the modem shield.
    • Remove the three identical Phillips screws, two on either side of the EMI fingers, and the remaining one on the right side of the modem shield.
    • Remove the larger Phillips screw that secures the EMI fingers to the modem board.
  • Remove the EMI fingers.
Agregar Comentario
Peel the modem shield away from the metal framework below, working from the right front and moving to the left.
  • Peel the modem shield away from the metal framework below, working from the right front and moving to the left.
Agregar Comentario
Remove the Phillips screw from the left side of the modem.
  • Remove the Phillips screw from the left side of the modem.
  • Pry up the right side of the modem.
Agregar Comentario
Lift the modem partially out and disconnect the cable on the left side.
  • Lift the modem partially out and disconnect the cable on the left side.
Agregar Comentario
Remove the Phillips screw from the left hinge.
  • Remove the Phillips screw from the left hinge.
  • Peel up the airport cable from beneath the yellow tape.
Agregar Comentario
Disconnect the large display data cable from the logic board and deroute it from the plastic and metal tabs.
  • Disconnect the large display data cable from the logic board and deroute it from the plastic and metal tabs.
Agregar Comentario
Disconnect the backlight cable from the logic board and deroute it.
  • Disconnect the backlight cable from the logic board and deroute it.
Agregar Comentario
Remove the three small Phillips screws from the clutch cover.
  • Remove the three small Phillips screws from the clutch cover.
When reinstalling, hold the display so the clutch cover is flush with the panel below. Make sure no wires are caught before tightening the screws.
Note that there are small hooks that hold the clutch cover down. When reinstalling, be sure to hook the cover to them from the back, or you will have problems with the cover catching on the lid as you close it.
Brandon Dusseau - Contestar
Finally, support the display with one hand while unscrewing the last Phillips screw from the right hinge (push the display gently down to avoid putting pressure on the screw).
  • Finally, support the display with one hand while unscrewing the last Phillips screw from the right hinge (push the display gently down to avoid putting pressure on the screw).
  • Remove the display assembly.
Agregar Comentario
Remove the two small Phillips screws from the RJ-11 board.
  • Remove the two small Phillips screws from the RJ-11 board.
Agregar Comentario
Push out the lower case rim and pull the RJ-11 board out of the computer.
  • Push out the lower case rim and pull the RJ-11 board out of the computer.
Agregar Comentario
Deroute the speaker cable from the metal framework and disconnect it from the logic board.
  • Deroute the speaker cable from the metal framework and disconnect it from the logic board.
I don’t believe you need to deroute the speaker cable; just disconnect it from the logic board and leave it taped on where it is.
John Hagan - Contestar
There are six screws to remove (if you have an iBook without Firewire the screw circled in orange will not be present):
  • There are six screws to remove (if you have an iBook without Firewire the screw circled in orange will not be present):
    • Two short, flat-headed Phillips screws near the battery compartment.
    • One short, round-headed Phillips near the speaker cable connector. (This is present on some models, but not others - especially the older ones)
    • One short, flat-headed Phillips between the ethernet and USB ports.
    • One short, flat-headed Phillips to the left of the hole-y (polite laughter) area.
    • One long, round-headed Phillips screw near the power receptacle.
Agregar Comentario
Lift the right side of the EMI shield up and pull it out of the computer.
  • Lift the right side of the EMI shield up and pull it out of the computer.
Agregar Comentario
Push down firmly on the logic board and pull the DC-In board up from its connectors and then to the left.
  • Push down firmly on the logic board and pull the DC-In board up from its connectors and then to the left.
Agregar Comentario
Remove the three 5 mm standoffs securing the hard drive to the logic board.
  • Remove the three 5 mm standoffs securing the hard drive to the logic board.
Agregar Comentario
Pull the hard drive cable up from the logic board, using the plastic loop.
  • Pull the hard drive cable up from the logic board, using the plastic loop.
  • Lift the hard drive, with metal bracket attached, from the logic board.
Agregar Comentario
Remove the following screw and standoffs (the standoffs progress from smallest to largest):
  • Remove the following screw and standoffs (the standoffs progress from smallest to largest):
    • One flat-headed Phillips screw near the left side of the RAM slot.
    • The smallest standoff, near where the left hinge used to be.
    • The slightly larger standoff, near where the right hinge used to be.
    • The even larger standoff, near the right side of the RAM slot.
    • The largest standoff, above where the optical drive used to be.
Agregar Comentario
Disconnect the charger board cable from the logic board.
  • Disconnect the charger board cable from the logic board.
Agregar Comentario
Grasp the logic board to the left of where the optical drive used to be and pull it up from the lower case.
  • Grasp the logic board to the left of where the optical drive used to be and pull it up from the lower case.
Agregar Comentario
Conclusión
5 personas más completaron esta guía.
Documentos Adjuntos
iRobot
Miembro Desde 24/09/09
1 Reputación
750 Guías creadas
Hi, Can anyone tell me if there is a 3v battery on the logic board, like in an iMac? My iBook has not been used in years and starts up and dies before completion! Any ideas!
Thanks!
dieperdors - Contestar
It's Soldered in so you might have to do some work to replace it
Chris -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 7
Últimos 30 Días: 36
Todo El Tiempo: 12,749
