Introducción
"I can see clearly now…oh wait, no I can't. Where am I?"
Having trouble seeing the viewfinder in your Zeal Optics iON goggles? The viewfinder lens could be scratched or cracked, so use this guide to replace it.
Qué necesitas
Hold the iON in your hands with your thumbs on the clips next to the middle of the lens.
Pull the rubber housing apart to release the first two clips.
Remove the four 7.1 mm Phillips screws securing the camera housing to the goggle frame.
Remove the two 7.5 mm Phillips screws on the front of the viewfinder housing.
Remove the four 7.1 mm Phillips screws from the back of the viewfinder housing.
Use your thumbs to lift the tabs holding the viewfinder lens to the LCD assembly.
Pull the viewfinder lens off of the viewfinder LCD.
Remove the rubber O-ring from the viewfinder lens.
The viewfinder lens remains.
