Introducción
No button response or viewfinder image in your Zeal Optics iON goggles? Use this guide to replace a faulty button board, which also connects to the viewfinder lens assembly.
In the next few steps, you will be releasing the clips that hold the lens in place. Do not try to completely remove the lens until all the clips have been released. Hold the iON in your hands with your thumbs on the clips next to the middle of the lens.
  • In the next few steps, you will be releasing the clips that hold the lens in place. Do not try to completely remove the lens until all the clips have been released.
  • Hold the iON in your hands with your thumbs on the clips next to the middle of the lens.
  • Pull the rubber housing apart to release the first two clips.
Agregar Comentario
Grab the inside of the plastic nose rest with your thumb and index finger. Rotate the nose rest upwards until you feel that it is free from the lens.
  • Grab the inside of the plastic nose rest with your thumb and index finger.
  • Rotate the nose rest upwards until you feel that it is free from the lens.
Agregar Comentario
Rotate the device 180 degrees. Grab the top of the goggle frame that holds the camera assembly.
  • Rotate the device 180 degrees.
  • Grab the top of the goggle frame that holds the camera assembly.
  • Rotate the frame outwards until you feel that the clips inside it are free.
Agregar Comentario
While firmly holding the goggles with the palm of one hand, grab the top right corner of the frame and rotate it away from the lens. While firmly holding the goggles with the palm of one hand, grab the top right corner of the frame and rotate it away from the lens.
  • While firmly holding the goggles with the palm of one hand, grab the top right corner of the frame and rotate it away from the lens.
Agregar Comentario
The lens should now be barely attached to the frame. If it still feels firmly attached, repeat any necessary steps to free the clips. While holding the goggles in one hand, use the other to grab the lens from opposite ends, and rotate it out of the housing and away from any remaining clips.
  • The lens should now be barely attached to the frame. If it still feels firmly attached, repeat any necessary steps to free the clips.
  • While holding the goggles in one hand, use the other to grab the lens from opposite ends, and rotate it out of the housing and away from any remaining clips.
Agregar Comentario
Remove the four 7.1 mm Phillips screws securing the camera housing to the goggle frame.
  • Remove the four 7.1 mm Phillips screws securing the camera housing to the goggle frame.
Agregar Comentario
Peel back the rubber battery cover from the inner left side of the frame. While firmly holding the battery cover, pull the bottom of the strap mount cover up and off of the frame While firmly holding the battery cover, pull the bottom of the strap mount cover up and off of the frame
  • Peel back the rubber battery cover from the inner left side of the frame.
  • While firmly holding the battery cover, pull the bottom of the strap mount cover up and off of the frame
Agregar Comentario
Once the bottom is free, continue pulling to free the top of the strap mount cover from the frame. Once the bottom is free, continue pulling to free the top of the strap mount cover from the frame.
  • Once the bottom is free, continue pulling to free the top of the strap mount cover from the frame.
Agregar Comentario
Pull the battery out of its recess in the frame. The battery is connected to the entire camera assembly and cannot be completely removed by itself.
  • Pull the battery out of its recess in the frame.
    • The battery is connected to the entire camera assembly and cannot be completely removed by itself.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Peel the rubber keypad cover up from the inner right side of the frame. While firmly holding the keypad cover, pull the top of the strap mount cover up and off of the frame While firmly holding the keypad cover, pull the top of the strap mount cover up and off of the frame
  • Peel the rubber keypad cover up from the inner right side of the frame.
  • While firmly holding the keypad cover, pull the top of the strap mount cover up and off of the frame
Agregar Comentario
Once the bottom is free, continue pulling to free the bottom of the strap mount cover from the frame. Once the bottom is free, continue pulling to free the bottom of the strap mount cover from the frame.
  • Once the bottom is free, continue pulling to free the bottom of the strap mount cover from the frame.
Agregar Comentario
Hold the strap mount cover away from the frame and remove the keypad. Hold the strap mount cover away from the frame and remove the keypad.
  • Hold the strap mount cover away from the frame and remove the keypad.
Agregar Comentario
Grab the viewfinder housing and pull it out of its recess. Just like the battery, the viewfinder housing is connected to the rest of the camera assembly and cannot be removed by itself. Just like the battery, the viewfinder housing is connected to the rest of the camera assembly and cannot be removed by itself.
  • Grab the viewfinder housing and pull it out of its recess.
    • Just like the battery, the viewfinder housing is connected to the rest of the camera assembly and cannot be removed by itself.
Agregar Comentario
Place one of your hands near the center of the frame with your thumb next to the camera housing. With your other hand, grab the camera housing and pull it up and out of the frame. With your other hand, grab the camera housing and pull it up and out of the frame.
  • Place one of your hands near the center of the frame with your thumb next to the camera housing.
  • With your other hand, grab the camera housing and pull it up and out of the frame.
Agregar Comentario
Remove the viewfinder assembly by pulling it through the opening in the top of the frame. Remove the viewfinder assembly by pulling it through the opening in the top of the frame.
  • Remove the viewfinder assembly by pulling it through the opening in the top of the frame.
Agregar Comentario
In the same manner described above, remove the battery from the frame. In the same manner described above, remove the battery from the frame.
  • In the same manner described above, remove the battery from the frame.
Agregar Comentario
Remove the two 7.5 mm Phillips screws on the front of the viewfinder housing. Flip the viewfinder housing over 180 degrees.
  • Remove the two 7.5 mm Phillips screws on the front of the viewfinder housing.
  • Flip the viewfinder housing over 180 degrees.
  • Remove the four 7.1 mm Phillips screws from the back of the viewfinder housing.
Agregar Comentario
Pull the two halves of the viewfinder housing apart. Pull the two halves of the viewfinder housing apart.
  • Pull the two halves of the viewfinder housing apart.
Agregar Comentario
Use the tip of a spudger to flip up the retaining flap on the LCD ribbon cable ZIF connector. Be sure to pry up on the hinged flap, not the connector itself.
  • Use the tip of a spudger to flip up the retaining flap on the LCD ribbon cable ZIF connector.
  • Be sure to pry up on the hinged flap, not the connector itself.
Agregar Comentario
Use the tip of a spudger to push out the retaining clip on the viewfinder backlight ribbon cable ZIF connector. Use the tip of a spudger to push out the retaining clip on the viewfinder backlight ribbon cable ZIF connector.
  • Use the tip of a spudger to push out the retaining clip on the viewfinder backlight ribbon cable ZIF connector.
Agregar Comentario
Using your fingers or tweezers, gently pull out the backlight ribbon cable from its connector on the button board. Using your fingers or tweezers, gently pull out the backlight ribbon cable from its connector on the button board.
  • Using your fingers or tweezers, gently pull out the backlight ribbon cable from its connector on the button board.
Agregar Comentario
Using your fingers or tweezers, remove the LCD ribbon cable from its connector on the button board. Using your fingers or tweezers, remove the LCD ribbon cable from its connector on the button board.
  • Using your fingers or tweezers, remove the LCD ribbon cable from its connector on the button board.
Agregar Comentario
Remove the viewfinder lens assembly from the viewfinder housing. Remove the viewfinder lens assembly from the viewfinder housing.
  • Remove the viewfinder lens assembly from the viewfinder housing.
Agregar Comentario
Use the tip of a spudger to flip up the retaining flap on the button board data cable ZIF connector. Be sure you are prying on the hinged flap, not the socket itself.
  • Use the tip of a spudger to flip up the retaining flap on the button board data cable ZIF connector.
  • Be sure you are prying on the hinged flap, not the socket itself.
Agregar Comentario
Remove the button board data cable from its socket on the button board. Remove the button board data cable from its socket on the button board.
  • Remove the button board data cable from its socket on the button board.
Agregar Comentario
Remove the three 4.5 mm Phillips screws securing the button board to the viewfinder housing.
  • Remove the three 4.5 mm Phillips screws securing the button board to the viewfinder housing.
Agregar Comentario
Remove the button board from the viewfinder housing. Remove the button board from the viewfinder housing.
  • Remove the button board from the viewfinder housing.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Eric Flores
Miembro Desde 31/07/12
128 Reputación
9 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 1
Todo El Tiempo: 957
