Saltar al contenido principal
ZTE Awe Screen Replacement
Qué necesitas
  1. ZTE Awe Screen Replacement, Detach the mid frame: paso 1, imagen 1 de 1
    • Use the Phillips Head 00 screw driver to unscrew the seven 0.1mm screws from the phone's mid frame.
  2. ZTE Awe Screen Replacement, Separate the mid frame and the digitizer: paso 2, imagen 1 de 3 ZTE Awe Screen Replacement, Separate the mid frame and the digitizer: paso 2, imagen 2 de 3 ZTE Awe Screen Replacement, Separate the mid frame and the digitizer: paso 2, imagen 3 de 3
    • Wedge the flat end of the spudger between the mid frame and the digitizer.
  3. ZTE Awe Screen Replacement, Expose the motherboard: paso 3, imagen 1 de 2 ZTE Awe Screen Replacement, Expose the motherboard: paso 3, imagen 2 de 2
    • Gently pry the mid frame away from the rest of the phone to expose the motherboard.
  4. ZTE Awe Screen Replacement, Remove the ribbon wires: paso 4, imagen 1 de 3 ZTE Awe Screen Replacement, Remove the ribbon wires: paso 4, imagen 2 de 3 ZTE Awe Screen Replacement, Remove the ribbon wires: paso 4, imagen 3 de 3
    • Use the tweezers to remove the four ribbon wires on the sides of the device.
  5. ZTE Awe Screen Replacement, Orient the motherboard: paso 5, imagen 1 de 1
    • Orient the motherboard to expose the mid frame.
  6. ZTE Awe Screen Replacement, Remove the connector: paso 6, imagen 1 de 3 ZTE Awe Screen Replacement, Remove the connector: paso 6, imagen 2 de 3 ZTE Awe Screen Replacement, Remove the connector: paso 6, imagen 3 de 3
    • Remove the connector to free the motherboard from the screen.
  7. ZTE Awe Screen Replacement, Remove the cover: paso 7, imagen 1 de 1
    • Remove the back cover from the phone.
  8. ZTE Awe Screen Replacement, Remove battery: paso 8, imagen 1 de 1
    • Pry the battery up and out of the phone.
  9. ZTE Awe Screen Replacement: paso 9, imagen 1 de 3 ZTE Awe Screen Replacement: paso 9, imagen 2 de 3 ZTE Awe Screen Replacement: paso 9, imagen 3 de 3
    • Gently wedge the spudger in between the glass screen and the mid frame.
  10. ZTE Awe Screen Replacement, Separate the motherboard from the screen: paso 10, imagen 1 de 2 ZTE Awe Screen Replacement, Separate the motherboard from the screen: paso 10, imagen 2 de 2
    • Carefully pry the screen away from the motherboard.
  11. ZTE Awe Screen Replacement, Remove the ribbons: paso 11, imagen 1 de 3 ZTE Awe Screen Replacement, Remove the ribbons: paso 11, imagen 2 de 3 ZTE Awe Screen Replacement, Remove the ribbons: paso 11, imagen 3 de 3
    • Be careful when removing the ribbon wires. They are delicate.
  12. ZTE Awe Screen Replacement, Remove the remaining ribbons: paso 12, imagen 1 de 3 ZTE Awe Screen Replacement, Remove the remaining ribbons: paso 12, imagen 2 de 3 ZTE Awe Screen Replacement, Remove the remaining ribbons: paso 12, imagen 3 de 3
    • Remove the remaining two ribbon wires from their connectors.
  13. ZTE Awe Screen Replacement, Expose the digitizer: paso 13, imagen 1 de 3 ZTE Awe Screen Replacement, Expose the digitizer: paso 13, imagen 2 de 3 ZTE Awe Screen Replacement, Expose the digitizer: paso 13, imagen 3 de 3
    • Wedge the plastic spudger between the screen and the digitizer.
    • Gently pry apart the screen from the digitizer.
Conclusión
12 personas más completaron esta guía.
Jennifer DeMeo
Miembro Desde 10/07/14
1,035 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 1-2, Leahy Fall 2014 Miembro de USF Tampa, Team 1-2, Leahy Fall 2014
USFT-LEAHY-F14S1G2
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 14
Todo El Tiempo: 14,178
