Saltar al contenido principal
Xiaomi Mi 4 Battery Replacement
Qué necesitas
  1. Xiaomi Mi 4 Battery Replacement, Rear Case/Midframe: paso 1, imagen 1 de 3 Xiaomi Mi 4 Battery Replacement, Rear Case/Midframe: paso 1, imagen 2 de 3 Xiaomi Mi 4 Battery Replacement, Rear Case/Midframe: paso 1, imagen 3 de 3
    • Check to make sure that the device is powered off.
    • Use a pin or paper clip to insert in the hole on the side of the phone next to the micro SIM cardholder to remove the tray.
    • Remove the SIM card tray from the Xiaomi Mi 4 and store it somewhere safe.
  2. Xiaomi Mi 4 Battery Replacement: paso 2, imagen 1 de 3 Xiaomi Mi 4 Battery Replacement: paso 2, imagen 2 de 3 Xiaomi Mi 4 Battery Replacement: paso 2, imagen 3 de 3
    Herramienta utilizada en este paso:
    Metal Spudger
    $2.99
    Comprar
    • Using the flat metal spudger and curved metal spudger, make a wedge between the plastic back cover and the inner frame
    • Using the second spudger, slowly work your way around the perimeter of the device
    • Listen for clicking sounds as you are prying the back cover away from the frame
    • As the back cover is almost completely removed, use the suction-cup tool to remove the plastic cover without damaging the back
  3. Xiaomi Mi 4 Battery Replacement: paso 3, imagen 1 de 3 Xiaomi Mi 4 Battery Replacement: paso 3, imagen 2 de 3 Xiaomi Mi 4 Battery Replacement: paso 3, imagen 3 de 3
    • Use a 000 phillips head screwdriver to remove the 10 1.2mm phillips head screws in the plastic frame that hold the motherboard and battery.
    • Use a 000 phillips head screwdriver to remove the 3 0.5mm phillips head screws in the plastic frame that hold the motherboard and battery.
    • Use the small plastic opening tool and place it in the slot on the bottom right corner of the inner frame and carefully pry it off.
  4. Xiaomi Mi 4 Battery Replacement, Battery: paso 4, imagen 1 de 3 Xiaomi Mi 4 Battery Replacement, Battery: paso 4, imagen 2 de 3 Xiaomi Mi 4 Battery Replacement, Battery: paso 4, imagen 3 de 3
    • Use tweezers to gently disconnect the connections that run across the battery and are connected to the motherboard.
    • Proceed to gently remove the tape like connector from the battery until it is completely off.
    • Use tweezer to disconnect battery’s wire from the motherboard.
  5. Xiaomi Mi 4 Battery Replacement: paso 5, imagen 1 de 2 Xiaomi Mi 4 Battery Replacement: paso 5, imagen 2 de 2
    • Use the plastic opening tool to gently pry the battery out of its casing for removal.
Conclusión
48 personas más completaron esta guía.
Equipo
USF Tampa, Team 15-6, Blackwell Fall 2015 Miembro de USF Tampa, Team 15-6, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G6
2 Miembros
10 Guías creadas
24 comentarios
Sir, I accidentally put a hole in battery while removing. Will this create a problem/explosion..
Apawilo Zawk - Contestar
Hey Apawilo. A punctured battery has potential to be very dangerous (Fire, harmful chemicals, etc), so please make sure to dispose of it at the nearest e-waste recycling site.
Geoff Wacker -
sir i am charging my phone but its percentage is not increasing ....this is a battery problem
adishsaggar123 - Contestar
im having the similar problem, when charging power increase slower and the consumption is faster than usual. please advice. thanks
Zeff Soo -
Hi..my xiaomi 4 cant be started.. after fully charged, it went blank n cant be restarted.. few days back, it was on n of for multiple time for several minutes...
Ezrat sam - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 20
Ultimos 30 días: 103
Todo El Tiempo: 147,275
