Saltar al contenido principal
Xbox One Optical Drive Laser Replacement
Qué necesitas
  1. Xbox One Optical Drive Laser Replacement, Optical Drive Case Screws: paso 1, imagen 1 de 1
    • Make sure the optical drive is not connected to any power source and is powered off.
    • Unscrew the four Phillips #1 screws on the top of the optical drive.
  2. Xbox One Optical Drive Laser Replacement, Optical Drive Case Lid: paso 2, imagen 1 de 1
    • Lift the lid off of the optical drive case, this should require little to no force.
  3. Xbox One Optical Drive Laser Replacement, Optical Drive Case: paso 3, imagen 1 de 2 Xbox One Optical Drive Laser Replacement, Optical Drive Case: paso 3, imagen 2 de 2
    • Slide the remaining optical drive case off of the internal components.
    • Internal components often snag on these points when removing the optical drive case.
  4. Xbox One Optical Drive Laser Replacement, ZIF Connectors: paso 4, imagen 1 de 2 Xbox One Optical Drive Laser Replacement, ZIF Connectors: paso 4, imagen 2 de 2
    • Locate the three ZIF connectors on the optical drive PCB.
    • Using tweezers, gently lift the tab on each ZIF connector to release the ribbon cables.
    • Remove the ribbon cable from each ZIF connector.
  5. Xbox One Optical Drive Laser Replacement, PCB Screws: paso 5, imagen 1 de 1
    • Unscrew the three Phillips #0 screws mounting the PCB.
  6. Xbox One Optical Drive Laser Replacement, Moving the PCB: paso 6, imagen 1 de 1
    • Gently lift the PCB and place it to the side.
    • When lifting the PCB, be careful to not detach the wires connecting the PCB to the motor.
  7. Xbox One Optical Drive Laser Replacement, Optical Drive Laser Screws: paso 7, imagen 1 de 1
    • Unscrew the three Phillips #0 screws mounting the optical drive laser.
  8. Xbox One Optical Drive Laser Replacement, Optical Drive Laser: paso 8, imagen 1 de 1
    • Lift the old optical drive laser from the unit and place in the new optical drive laser.
Conclusión
6 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 30
Ultimos 30 días: 149
Todo El Tiempo: 4,309
