Introducción
Can't cycle through your grenades in Halo 3? Install some new bumpers and stick your enemies!
Depress the battery release button on the top of the controller. Remove the battery holder from the controller.
  • Depress the battery release button on the top of the controller.
  • Remove the battery holder from the controller.
  • The standard option for Xbox 360 Wireless Controllers Battery Packs is AA batteries. A rechargeable battery is also available, but both battery options are removed from the controller in the same way.
Agregar Comentario
  • Use a pair of tweezers to peel the barcode sticker from the battery compartment.
Agregar Comentario
Remove the seven 9.3 mm  T8 Security Torx screws securing the rear case to the front case.
  • Remove the seven 9.3 mm T8 Security Torx screws securing the rear case to the front case.
Any recommendation on which set of Security Torx tools to use? I've already purchased 2 kits, one of those being sold as "Xbox controller tools" but the diameter of the head does not fit the hole on the controller and that's critical for the 2 screws on the bottom. The tools must obviously be thinner in diameter and long enough to get there.
Arnie - Contestar
How to open an XBOX 360 controller without a special screwdriver. http://www.instructables.com/id/How-to-o... Works perfectly.
Louis - Contestar
A lot of thanks for your comment. It's very usefull
Echedey -
I picked up a handy torx key set from Auto Zone. Was about $10, no lose driver bits. has both sizes you need to repair the controller and the console. Here's the link:
http://www.autozone.com/autozone/accesso...
FierDancr - Contestar
It doesn't really matter which set of bits you by or what brand makes them, Torx bits (and the security versions of them) are generic & come in standardized sizes. You do not need a special "xbox" tool kit, you just need a size 8 torx security bit, no matter what brand makes the bit/kit. Those types of "specialty kits" are usually just collections of generic bits that you can buy at a hardware store in a regular bit set. The difference is that a general bit set will have bits for screws that a specific item doesn't have in it, whereas a specialty kit will only include bits for the types & sizes of fasteners used in the specified item.
BTW, with the smaller sizes of torx security bits you can try breaking off the little post in the middle with needlenose pliers or something else that can fit in the there. Even if the post doesn't break off cleanly, it's usually short enough to fit a regular (non security) torx bit in the slot.
Nerfbomb - Contestar
  • Insert a Spudger between the front and rear cases along the left edge of the controller.
  • Rotate the spudger toward the front of the controller, prying the two cases apart.
Agregar Comentario
Insert a spudger between the front and rear cases, near the headphone jack. Rotate the spudger toward the front of the controller to pry the two cases apart.
  • Insert a spudger between the front and rear cases, near the headphone jack.
  • Rotate the spudger toward the front of the controller to pry the two cases apart.
Agregar Comentario
Grasp the controller by the battery compartment and the headphone jack. Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
  • Grasp the controller by the battery compartment and the headphone jack.
  • Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
  • The battery contact springs are held in place by slots in the battery housing in the rear case. Be sure to realign them properly during reassembly.
Agregar Comentario
Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board. Lift the vibration motor out of the front case.
  • Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
  • Lift the vibration motor out of the front case.
Agregar Comentario
Remove the vibration motor from the other side of the controller using the same method previously described. The right motor has significantly more counterweight than the left motor.
  • Remove the vibration motor from the other side of the controller using the same method previously described.
  • The right motor has significantly more counterweight than the left motor.
The opposite was true for the controller I just opened. It was the left motor counterweight (as you hold the controller normally) which had more weight. Perhaps it doesn't matter which goes where?
Bob S - Contestar
Lifting from the headphone jack and power plug, remove the logic board from the front case. Lifting from the headphone jack and power plug, remove the logic board from the front case.
  • Lifting from the headphone jack and power plug, remove the logic board from the front case.
What if you're having difficulty taking the logic board out?
Xander Uchida - Contestar
In my experience with my controller, the logic board lifts out very easily, there are no tabs or fasteners holding it in.
So, if you're having difficulty taking the logic board out, call a friend with average hand dexterity & motor skills to do it for you.
Orient the controller so that the front of the controller is facing toward you. Lift the bumper panel off the front case.
  • Orient the controller so that the front of the controller is facing toward you.
  • Lift the bumper panel off the front case.
Agregar Comentario
Conclusión
23 personas más completaron esta guía.
Brett Hartt
Miembro Desde 12/04/10
106,162 Reputación
324 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
113 Miembros
6,000 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 27
Últimos 30 Días: 150
Todo El Tiempo: 44,314
