Saltar al contenido principal
Xbox 360 Jammed CD Belt Replacement
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
  1. Xbox 360 Jammed CD Belt  Replacement, Jammed CD Belt: paso 1, imagen 1 de 1
    • Remove the white plastic casing covering the Xbox.
    • Place the Xbox with the front part of the console facing you. Use the flat surface of the tweezers to prop the top part of the casing to remove the front casing of the console.
  2. Xbox 360 Jammed CD Belt  Replacement: paso 2, imagen 1 de 3 Xbox 360 Jammed CD Belt  Replacement: paso 2, imagen 2 de 3 Xbox 360 Jammed CD Belt  Replacement: paso 2, imagen 3 de 3
    • Stand the Xbox up so the bottom part is facing up. Use your nail and poke at the second hole on the second row on the side of the Xbox.
    • The next hole is the twenty-first hole on the third row.
    • The final hole is the second to last hole on the fourth row. Repeat on each side, top and bottom.
  3. Xbox 360 Jammed CD Belt  Replacement: paso 3, imagen 1 de 3 Xbox 360 Jammed CD Belt  Replacement: paso 3, imagen 2 de 3 Xbox 360 Jammed CD Belt  Replacement: paso 3, imagen 3 de 3
    • Remove grey plastic piece and place the console with the front facing you.
    • You will see four clips. Take a multi-screwdriver and use the flat screw or a plastic spudger to unhook the clips.
    • Once unhooked, flip Xbox so the bottom of the console is facing you.
  4. Xbox 360 Jammed CD Belt  Replacement: paso 4, imagen 1 de 2 Xbox 360 Jammed CD Belt  Replacement: paso 4, imagen 2 de 2
    • Take the tweezers, or pliers, and poke the seven holes that are visible to you. Remove the cover.
  5. Xbox 360 Jammed CD Belt  Replacement: paso 5, imagen 1 de 2 Xbox 360 Jammed CD Belt  Replacement: paso 5, imagen 2 de 2
    • Place the console with the metal side facing you and take your multi-screwdriver (using the star head) and remove the six screws labeled in the picture below
  6. Xbox 360 Jammed CD Belt  Replacement: paso 6, imagen 1 de 1
    • Remove the other half of the white casing.
  7. Xbox 360 Jammed CD Belt  Replacement: paso 7, imagen 1 de 3 Xbox 360 Jammed CD Belt  Replacement: paso 7, imagen 2 de 3 Xbox 360 Jammed CD Belt  Replacement: paso 7, imagen 3 de 3
    • Flip the console with the hardware facing up. There will be a grey box that is connected to the console, with white and black wires exposed.
    • Disconnect both wires and remove half of the piece of silver electrical tape, careful to not remove the entire tape.
  8. Xbox 360 Jammed CD Belt  Replacement: paso 8, imagen 1 de 1
    • Place the box so the bottom is facing up. Remove the four screws labeled in the picture below with a multi-screwdriver with the five-point head.
  9. Xbox 360 Jammed CD Belt  Replacement: paso 9, imagen 1 de 3 Xbox 360 Jammed CD Belt  Replacement: paso 9, imagen 2 de 3 Xbox 360 Jammed CD Belt  Replacement: paso 9, imagen 3 de 3
    • Place pressure on black rods to remove the top casing of the drive.
    • Place the drive facing you. This should expose a small hole.
    • Take the nail and gently unwind the gear inside the hole. When finished, the tray should be out.
  10. Xbox 360 Jammed CD Belt  Replacement: paso 10, imagen 1 de 2 Xbox 360 Jammed CD Belt  Replacement: paso 10, imagen 2 de 2
    • Use your tweezers to remove the band.
  11. Xbox 360 Jammed CD Belt  Replacement: paso 11, imagen 1 de 1
    • Replace old band with new.
    • To reassemble, complete these steps in reverse order.
    • You may hear clicking sounds when re-attaching the pieces held together by clips. This is normal, and expected.
Conclusión
2 personas más completaron esta guía.
joey
Miembro Desde 09/11/15
242 Reputación
1 Guía escrita
Equipo
Un comentario
Lol. Avoid drugs & alchohol or you could potentially make an err. Wow. Like the guide though! Thx.
Chris Fisher - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 974
