Saltar al contenido principal
XBOX 360 Power Brick Fan Replacement
Qué necesitas
    • This is how my power brick sounded when I decided I couldn't bear it anymore
  1. XBOX 360 Power Brick Fan Replacement, Taking off the Screws: paso 2, imagen 1 de 3 XBOX 360 Power Brick Fan Replacement, Taking off the Screws: paso 2, imagen 2 de 3 XBOX 360 Power Brick Fan Replacement, Taking off the Screws: paso 2, imagen 3 de 3
    • Be sure to unplug the power supply before you begin the procedure.
    • To take off the 4 screws, you need to pry off the rubber feet
    • Most of the time, the rubber part will become detached from the plastic one
    • Use pliers if necessary
  2. XBOX 360 Power Brick Fan Replacement, Open up the case: paso 3, imagen 1 de 3 XBOX 360 Power Brick Fan Replacement, Open up the case: paso 3, imagen 2 de 3 XBOX 360 Power Brick Fan Replacement, Open up the case: paso 3, imagen 3 de 3
    • After removing the 4 screws, pry along the edge to get the two halves separated
  3. XBOX 360 Power Brick Fan Replacement, Remove PCB from main housing: paso 4, imagen 1 de 3 XBOX 360 Power Brick Fan Replacement, Remove PCB from main housing: paso 4, imagen 2 de 3 XBOX 360 Power Brick Fan Replacement, Remove PCB from main housing: paso 4, imagen 3 de 3
    • Lift up the light diffuser
    • Lift up the power-connector & DC out wire
    • The main board should come out relatively easily now.
  4. XBOX 360 Power Brick Fan Replacement, Disconnect the Fan: paso 5, imagen 1 de 2 XBOX 360 Power Brick Fan Replacement, Disconnect the Fan: paso 5, imagen 2 de 2
    • Disconnect the fan from under the main heatsink.
    • Be careful when pulling the wire out, as it usually gets stuck between the heatsink and capacitors - patience is, as always, key
  5. XBOX 360 Power Brick Fan Replacement, Taking Fan Assembly Out of Upper Case: paso 6, imagen 1 de 3 XBOX 360 Power Brick Fan Replacement, Taking Fan Assembly Out of Upper Case: paso 6, imagen 2 de 3 XBOX 360 Power Brick Fan Replacement, Taking Fan Assembly Out of Upper Case: paso 6, imagen 3 de 3
    • First - just take out the two smaller screws, whilst leaving in the two bigger ones
    • After that's done, only a few clamps hold the assembly in
  6. XBOX 360 Power Brick Fan Replacement, More Screws ...: paso 7, imagen 1 de 3 XBOX 360 Power Brick Fan Replacement, More Screws ...: paso 7, imagen 2 de 3 XBOX 360 Power Brick Fan Replacement, More Screws ...: paso 7, imagen 3 de 3
    • There is yet another sub-assembly holding the fan in - I tip my hat to whoever designed this
  7. XBOX 360 Power Brick Fan Replacement, Fan Size: paso 8, imagen 1 de 2 XBOX 360 Power Brick Fan Replacement, Fan Size: paso 8, imagen 2 de 2
    • The dimension of the fan-holder in my unit might differ from yours, as Microsoft seems to use different suppliers each day for good reasons (such as probably getting more air-flow related complications packed in)
  8. XBOX 360 Power Brick Fan Replacement, Removing the Fan: paso 9, imagen 1 de 3 XBOX 360 Power Brick Fan Replacement, Removing the Fan: paso 9, imagen 2 de 3 XBOX 360 Power Brick Fan Replacement, Removing the Fan: paso 9, imagen 3 de 3
    • To actually get to the fan, the faceplate needs removing as well
    • Once that's done, there's a pin holding the wire down
    • As you probably won't be reusing the piece of junk fan that brought you to this guide, I suggest you go medieval prying it out - works a treat
  9. XBOX 360 Power Brick Fan Replacement, Replacing the Fan: paso 10, imagen 1 de 2 XBOX 360 Power Brick Fan Replacement, Replacing the Fan: paso 10, imagen 2 de 2
    • With the fan out, the next step is fitting in a replacement
    • !!! Make sure to get a 12V fan, of correct dimensions
    • I got mine from an old laptop cooler
  10. XBOX 360 Power Brick Fan Replacement, Mounting new Fan: paso 11, imagen 1 de 2 XBOX 360 Power Brick Fan Replacement, Mounting new Fan: paso 11, imagen 2 de 2
    • I first sanded down the little protrusion which held the old fan in place
    • Then used some epoxy resin (Poxipol) to glue down the new fan
    • To maximize airflow, mount it skewed to the right (from 2nd picture's point of view)
  11. XBOX 360 Power Brick Fan Replacement, Connecting & Testing: paso 12, imagen 1 de 3 XBOX 360 Power Brick Fan Replacement, Connecting & Testing: paso 12, imagen 2 de 3 XBOX 360 Power Brick Fan Replacement, Connecting & Testing: paso 12, imagen 3 de 3
    • Before the resin sets - make sure your fan can spin freely
    • Prep the wire ends by applying solder to them
    • Next, feed some tiny shrink wrap over the cable, THEN solder them together (somehow I always end up having to desolder stuff ...:)
  12. XBOX 360 Power Brick Fan Replacement, Done !: paso 13, imagen 1 de 1
    • Just put everything back together, and hopefully you found the right fan that's weak enough to not be louder than your XBOX
Linea de Meta
17 personas más completaron esta guía.
Darie H
Miembro Desde 11/20/12
4,580 Reputación
5 Guías creadas
6 comentarios
This is a well written guide. I stopped at step 7 as I only wanted to open the power supply in order to clean it out. I was quite surprised to see how much dirt/dust was trapped inside. Using a can of air duster in the vent holes is not even close to being sufficient to clean out the inside alone. I highly suggest that anyone who owns this system disassemble and clean their power supply, and console, at least every couple of years to increase longevity of your Xbox. Remember, dust and dirt build up is one of the biggest killers of these devices. I had a different variation of the Xbox 360 power supply then what is shown in this guide. Nonetheless, the process is simple. After I got the rubber boots off, which isn't hard, it only took me 1hr 7min 4.5sec to disassemble, clean and reassemble the power supply. I didn't start timing until the boots were off, don't ask why. It's now just as clean as the day I bought it. Thanks for the guide!
Navy Vet 2015 - Contestar
where can i get another fan?
William Anderson - Contestar
thanks for the reference, i found a new fan on Ebay, ADDA AB4512HX 4$$$$ ;-) great.
honfu2000 - Contestar
Could it be used without the fan at all? I had my PSU serviced, and I think they removed the fan completely (it's 100% silent). Should I be worried?
Marcello - Contestar
Hello so my power brick looks just like this one however it looks different on the inside. I can’t get to the fan part. There are no screws and it’s all covered with plastic. I don’t know how to open it up without breaking the plastic.
Bean Nuggett - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 37
Ultimos 30 días: 140
Todo El Tiempo: 24,112
