Saltar al contenido principal
Waring 51BL29 Drive Coupling Replacement
Qué necesitas
  1. Waring 51BL29 Drive Coupling Replacement, Bottom Panel: paso 1, imagen 1 de 2 Waring 51BL29 Drive Coupling Replacement, Bottom Panel: paso 1, imagen 2 de 2
    • Turn the blender on its side so the bottom panel is facing you.
    • Unscrew the 22mm Phillips #1 screw on the indent of the panel.
    • Unscrew the 3 screws in the rubber holes.
  2. Waring 51BL29 Drive Coupling Replacement: paso 2, imagen 1 de 1
    • Remove the bottom panel.
  3. Waring 51BL29 Drive Coupling Replacement, Drive Coupling: paso 3, imagen 1 de 1
    • Place the screwdriver in the head of the middle flat-head screw.
  4. Waring 51BL29 Drive Coupling Replacement: paso 4, imagen 1 de 1
    • Unscrew this screw while holding the coupling with your other hand and not allowing it to rotate.
    • This screw may be reverse-threaded.
  5. Waring 51BL29 Drive Coupling Replacement: paso 5, imagen 1 de 1
    • Once the coupling mechanism has been loosened all the way, gently pull it off the top of the blender.
Conclusión
4 personas más completaron esta guía.
Dean Becker
Miembro Desde 04/17/17
470 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S15-G4, Banghart Spring 2017 Miembro de Cal Poly, Team S15-G4, Banghart Spring 2017
CPSU-BANGHART-S17S15G4
4 Miembros
5 Guías creadas
Un comentario
Do you happen to know where I can purchase this replacement part?
Jessica Dye - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 18
Ultimos 30 días: 43
Todo El Tiempo: 4,292
