Introducción
Follow this guide to properly replace the keyboard.
Push the highlighted button in the direction in which the antenna is pointing. The battery will release and pop up.
  • Push the highlighted button in the direction in which the antenna is pointing. The battery will release and pop up.
Agregar Comentario
Remove the battery.
  • Remove the battery.
Agregar Comentario
Identify the antenna. It is the extendable plastic component pictured here.
  • Identify the antenna. It is the extendable plastic component pictured here.
Agregar Comentario
Twist the base in a counter-clockwise motion to unscrew the antenna.
  • Twist the base in a counter-clockwise motion to unscrew the antenna.
Agregar Comentario
The antenna should slide right out of the phone when finished. The antenna should slide right out of the phone when finished.
  • The antenna should slide right out of the phone when finished.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the small rubber grommet using a plastic opening tool as shown.
  • Remove the small rubber grommet using a plastic opening tool as shown.
Agregar Comentario
Unscrew all five of the highlighted screws using a Phillips #00 Screwdriver.
  • Unscrew all five of the highlighted screws using a Phillips #00 Screwdriver.
Agregar Comentario
Use a plastic opening tool to separate the two pieces that form the outer case of the phone.
  • Use a plastic opening tool to separate the two pieces that form the outer case of the phone.
  • Caution: prying the two pieces apart may be difficult.
Agregar Comentario
Remove the posterior piece of the outer case.
  • Remove the posterior piece of the outer case.
Agregar Comentario
Remove the speaker using a plastic opening tool.
  • Remove the speaker using a plastic opening tool.
Agregar Comentario
Remove the wire attached to the speaker from the logic board using tweezers. Remove the wire attached to the speaker from the logic board using tweezers.
  • Remove the wire attached to the speaker from the logic board using tweezers.
Agregar Comentario
Detach the highlighted piece from the logic board using a plastic opening tool.
  • Detach the highlighted piece from the logic board using a plastic opening tool.
Agregar Comentario
Remove the logic board from the anterior piece of the outer case using the plastic opening tool. Remove the logic board from the anterior piece of the outer case using the plastic opening tool.
  • Remove the logic board from the anterior piece of the outer case using the plastic opening tool.
Agregar Comentario
Remove the keyboard.
  • Remove the keyboard.
Agregar Comentario
Conclusión
Bryon Hazlewood
Miembro Desde 03/10/12
1 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 24-26, Regan Fall 2012 Miembro de Cal Poly, Team 24-26, Regan Fall 2012
CPSU-REGAN-F12S24G26
4 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 261
