Saltar al contenido principal
Trek 820 Light Mount Replacement
Qué necesitas
  1. Trek 820 Light Mount Replacement, Light Mount: paso 1, imagen 1 de 2 Trek 820 Light Mount Replacement, Light Mount: paso 1, imagen 2 de 2
    • Clean the area where the light mount will be installed with a soft cloth.
    • Placing the light mount close to the center stem.
  2. Trek 820 Light Mount Replacement: paso 2, imagen 1 de 1
    • Remove the strap from the light mount fitting.
    • Stretch the strap clockwise around the handlebars.
  3. Trek 820 Light Mount Replacement: paso 3, imagen 1 de 1
    • Slide the strap through the slot and fasten to a snug, but moveable fit.
    • Do not fasten too tight as this will make it difficult to fine tune light mount placement.
  4. Trek 820 Light Mount Replacement: paso 4, imagen 1 de 1
    • Pull the strap tightly through the clasps at the bottom of the mount.
  5. Trek 820 Light Mount Replacement: paso 5, imagen 1 de 2 Trek 820 Light Mount Replacement: paso 5, imagen 2 de 2
    • Place the fastening screw in the rear screw port on the light mount.
    • Twist the screw clockwise using your hands until fully fastened.
Conclusión
Now you have a light mount ready for safer night rides on your Trek bicycle!
Equipo
Cal Poly, Team 1-1, Propen Fall 2012 Miembro de Cal Poly, Team 1-1, Propen Fall 2012
CPSU-PROPEN-F12S1G1
5 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 14
Todo El Tiempo: 856
