Introducción
Have you ever wondered how to do basic maintenance on your own truck? This guide teaches even the clumsiest handyman how to change their own oil with only a few basic tools.
Qué necesitas
Locate the oil drain plug. The plug is located underneath the front of the truck on the bottom of the engine crank case.
Pull the hood release latch. The latch is located inside of the car under the steering wheel.
Pull the hood release. The release is located under the front center of the hood.
Use the hood support rod to keep the hood propped up. The rod is located along the front edge of the engine compartment.
Set the torque wrench to 32 ft-lbs.
Check if all of the oil has drained from the engine by seeing if the oil is still flowing into the drain pan.
Wipe any spills on the ground.
Replace the drain plug.
Use the 14mm socket torque wrench to tighten the drain plug until the wrench makes a "clicking" noise.
Start the truck and let it run for 5 minutes before turning off the engine.
Locate the engine dipstick. The dipstick is located on the left side of the engine compartment and is designated by a yellow ring.
Remove the dipstick and wipe it clean.
Reinsert and remove the dipstick to see if the oil is between the two dots on the dipstick.
13 personas más completaron esta guía.
6 comentarios
Can you show me the 2007 Toyota Tacoma Oil Change also ?
This is not applicable to the 2019 (and probably later) models. They now use canister filters located under the skid plate.
