Saltar al contenido principal
Toyota Corolla Headlight/ignition key buzzer disable
Qué necesitas
  1. Toyota Corolla Headlight/ignition key buzzer disable, Toyota Corolla Headlight/ignition key buzzer disable: paso 1, imagen 1 de 2 Toyota Corolla Headlight/ignition key buzzer disable, Toyota Corolla Headlight/ignition key buzzer disable: paso 1, imagen 2 de 2
    • Start by removing the hood over the instrument cluster. Pull the hood straight out towards the steering wheel.
  2. Toyota Corolla Headlight/ignition key buzzer disable: paso 2, imagen 1 de 2 Toyota Corolla Headlight/ignition key buzzer disable: paso 2, imagen 2 de 2
    • After removing the hood, undo the four screws securing the instrument cluster and pull forward.
    • The buzzer is accessed through a grill in the bottom of the instrument cluster/combination meter. Simply poke a sharp object into the grill and mash up the speaker dome to neutralize the buzzer!
Conclusión
7 personas más completaron esta guía.
bt1993
Miembro Desde 02/13/13
372 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 15
Ultimos 30 días: 67
Todo El Tiempo: 7,929
