Introducción
Learn how to replace your laptop's RAM.
Partes
No se requieren partes.
Use a #1 Phillips head screwdriver to remove the screws on the RAM's cover panel, as seen in image. Then, use a flat edge tool to pry the cover off, as seen in image. Use your fingers to push the RAM tabs, as seen in image, that secure the RAM outward (away from the RAM). The RAM should then pop up.
  • Use a #1 Phillips head screwdriver to remove the screws on the RAM's cover panel, as seen in image.
  • Then, use a flat edge tool to pry the cover off, as seen in image.
  • Use your fingers to push the RAM tabs, as seen in image, that secure the RAM outward (away from the RAM). The RAM should then pop up.
  • Finally, gently pull the RAM away from the connection. (Repeat this process until all the RAM has been removed from the device).
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Conclusión
3 personas más completaron esta guía.
Equipo
Cal Poly, Team 10-42, Garner Spring 2010 Miembro de Cal Poly, Team 10-42, Garner Spring 2010
CPSU-GARNER-S10S10G42
5 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 5
Todo El Tiempo: 4,538
