Introducción
This guide will show you how to replace your keyboard.
Partes
No se requieren partes.
Carefully pry off the panel above the keyboard from the both sides of the laptop using a flat edge tool. Push back the screen until it is horizontal with the laptop. Gently remove the clips that hold the panel onto the screen hinges.
  • Carefully pry off the panel above the keyboard from the both sides of the laptop using a flat edge tool.
  • Push back the screen until it is horizontal with the laptop.
  • Gently remove the clips that hold the panel onto the screen hinges.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the two screws on the upper outer edges of the keyboard with a #1 Phillips head screwdriver. Gently pry the keyboard from the laptop on the upper outer edges using the flat edge tool. Slowly lift the keyboard away from the laptop until you are able to remove the ribbon that connects the keyboard to the laptop.
  • Remove the two screws on the upper outer edges of the keyboard with a #1 Phillips head screwdriver.
  • Gently pry the keyboard from the laptop on the upper outer edges using the flat edge tool.
  • Slowly lift the keyboard away from the laptop until you are able to remove the ribbon that connects the keyboard to the laptop.
  • CAUTION!! Make sure you remove the keyboard slowly to avoid damaging the ribbon cable.
Agregar Comentario
Conclusión
5 personas más completaron esta guía.
Aryn Pauly
Miembro Desde 29/04/10
1 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 10-42, Garner Spring 2010 Miembro de Cal Poly, Team 10-42, Garner Spring 2010
CPSU-GARNER-S10S10G42
5 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 3
Todo El Tiempo: 8,053
