Introducción
This guide will demonstrate how to dismantle and replace components of your computers display (screen).
Using a bladed tool, gently pry up the display hinge cover. Using a bladed tool, gently pry up the display hinge cover.
  • Using a bladed tool, gently pry up the display hinge cover.
Agregar Comentario
After folding the display completely back, lift up on the display hinge cover and remove it. After folding the display completely back, lift up on the display hinge cover and remove it.
  • After folding the display completely back, lift up on the display hinge cover and remove it.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the keyboard. For keyboard removal instructions, see the keyboard guide here: Toshiba Satellite M45 Keyboard Replacement
Agregar Comentario
Remove the black electrical tape covering the black-and-white antenna cable. There will be 2-3 pieces of tape.
  • Remove the black electrical tape covering the black-and-white antenna cable. There will be 2-3 pieces of tape.
  • After the tape has been removed, close the laptop display, flip the laptop over, and disconnect the black-and-white antenna cables from the WiFi Card.
  • Once the antenna cables are disconnected from the modem card, flip the laptop back over and open the display.
Agregar Comentario
Remove the two screws securing the display hinges with a #1 size Phillips head screwdriver. It is recommended to keep the screws in a small cup so that you don't lose them. Remove the four screws on the back of the laptop holding the screen in place with a #1 screwdriver. There are two on each side. Remove the four screws on the back of the laptop holding the screen in place with a #1 screwdriver. There are two on each side.
  • Remove the two screws securing the display hinges with a #1 size Phillips head screwdriver. It is recommended to keep the screws in a small cup so that you don't lose them.
  • Remove the four screws on the back of the laptop holding the screen in place with a #1 screwdriver. There are two on each side.
Agregar Comentario
Remove the display's video connector by gently pulling up.
  • Remove the display's video connector by gently pulling up.
  • Remove the black-and-white antenna cable from the groove.
  • Your display can now be removed.
Agregar Comentario
Conclusión
3 personas más completaron esta guía.
Aryn Pauly
Miembro Desde 29/04/10
1 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 10-42, Garner Spring 2010 Miembro de Cal Poly, Team 10-42, Garner Spring 2010
CPSU-GARNER-S10S10G42
5 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 7,797
