Introducción
This guide describes how to remove the cooling unit of the Toshiba Satellite M45 laptop.
Partes
No se requieren partes.
Remove the cover from the cooling unit. Remove the cover from the cooling unit. Remove the cover from the cooling unit.
  • Remove the cover from the cooling unit.
Agregar Comentario
Unscrew the copper heat-sink using a #1 screwdriver, and then lift it free. Do not get any thermal grease on any components. This part can now be replaced. Unscrew the copper heat-sink using a #1 screwdriver, and then lift it free. Do not get any thermal grease on any components. This part can now be replaced.
  • Unscrew the copper heat-sink using a #1 screwdriver, and then lift it free. Do not get any thermal grease on any components. This part can now be replaced.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Follow the tear-down guide until you have access to the fan unit on the motherboard.
  • Follow the tear-down guide until you have access to the fan unit on the motherboard.
Agregar Comentario
Unscrew the fan unit from the motherboard using a #0 screwdriver. Once the fan is unscrewed and unplugged from the motherboard, it can be replaced. Unscrew the fan unit from the motherboard using a #0 screwdriver. Once the fan is unscrewed and unplugged from the motherboard, it can be replaced. Unscrew the fan unit from the motherboard using a #0 screwdriver. Once the fan is unscrewed and unplugged from the motherboard, it can be replaced.
  • Unscrew the fan unit from the motherboard using a #0 screwdriver. Once the fan is unscrewed and unplugged from the motherboard, it can be replaced.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Stephen
Miembro Desde 20/04/10
352 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 10-42, Garner Spring 2010 Miembro de Cal Poly, Team 10-42, Garner Spring 2010
CPSU-GARNER-S10S10G42
5 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 4
Todo El Tiempo: 5,309
