Partes
No se requieren partes.
Unlatch the battery by pushing outward on both latches.
  • Unlatch the battery by pushing outward on both latches.
Agregar Comentario
Slide battery out.
  • Slide battery out.
Agregar Comentario
Remove the five "F2" screws with a Phillips #0 screwdriver.
  • Remove the five "F2" screws with a Phillips #0 screwdriver.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Insert the plastic opening tool above the F1 key. Apply upward pressure until the black plastic strip snaps off. The entire strip will easily come off from left to right.
  • Insert the plastic opening tool above the F1 key.
  • Apply upward pressure until the black plastic strip snaps off. The entire strip will easily come off from left to right.
Agregar Comentario
Find the screws above the F1 and INS keys. Unscrew both screws with a Phillips #0 screwdriver.
  • Find the screws above the F1 and INS keys.
  • Unscrew both screws with a Phillips #0 screwdriver.
Agregar Comentario
Slowly lift the top edge of the keyboard out with your fingers. The ribbon cable located on the back of the keyboard will become accessible.
  • Slowly lift the top edge of the keyboard out with your fingers.
  • The ribbon cable located on the back of the keyboard will become accessible.
Agregar Comentario
Locate the black ribbon cable flap. Detach flap with plastic opening tool.  The ribbon cable will become free.
  • Locate the black ribbon cable flap.
  • Detach flap with plastic opening tool. The ribbon cable will become free.
Agregar Comentario
Your keyboard has now been successfully removed.
  • Your keyboard has now been successfully removed.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team 4-3, Regan Spring 2011 Miembro de Cal Poly, Team 4-3, Regan Spring 2011
CPSU-REGAN-S11S4G3
5 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 4,401
