Introducción
Replacing the keyboard is an intermediate level repair. Following the instructions carefully will help you successfully replace your keyboard.
Partes
No se requieren partes.
Locate the battery locks on the bottom of the laptop. Slide the right lock outwards, until it locks into place. Slide and hold the left lock outwards and hold it in place.
  • Locate the battery locks on the bottom of the laptop.
  • Slide the right lock outwards, until it locks into place.
  • Slide and hold the left lock outwards and hold it in place.
Agregar Comentario
While holding the lock in place, slide the battery out towards you.
  • While holding the lock in place, slide the battery out towards you.
Agregar Comentario
Using a #1 Phillips screwdriver, remove the 5.8 mm screw in the battery slot.
  • Using a #1 Phillips screwdriver, remove the 5.8 mm screw in the battery slot.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Use a plastic opening tool to pry off the plastic panel above the keyboard.
  • Use a plastic opening tool to pry off the plastic panel above the keyboard.
Agregar Comentario
Unscrew the four 3.7 mm screws at the top of the keyboard using a #1 Phillips screwdriver. Unscrew the four 3.7 mm screws at the top of the keyboard using a #1 Phillips screwdriver.
  • Unscrew the four 3.7 mm screws at the top of the keyboard using a #1 Phillips screwdriver.
Agregar Comentario
Slowly lift the keyboard out, up and towards the screen.
  • Slowly lift the keyboard out, up and towards the screen.
  • Do not try to remove the keyboard completely because it is still attached to the motherboard.
Agregar Comentario
Using a plastic opening tool, flip the ZIF connector up to release the ribbon and the keyboard.
  • Using a plastic opening tool, flip the ZIF connector up to release the ribbon and the keyboard.
Agregar Comentario
Conclusión
3 personas más completaron esta guía.
Jerry Wakai
Miembro Desde 31/01/13
284 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 7-7, Maness Winter 2013 Miembro de Cal Poly, Team 7-7, Maness Winter 2013
CPSU-MANESS-W13S7G7
5 Miembros
6 Guías creadas
Nice little guide. The only thing I can really think to add would be on the last part for those of us who are super-paranoid about breaking something. If you could add a picture of what the ZIF connector looks like after it's opened would help some.
I appreciate the guide, thanks. :)
Christopher Tidwell - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 7
Últimos 30 Días: 23
Todo El Tiempo: 3,976
