Introducción
Use this guide when your keyboard does not work or if any keys falls off. You cannot replace individual keys.
Partes
No se requieren partes.
Slide both of the latches to the outside to release the battery. Slide both of the latches to the outside to release the battery.
  • Slide both of the latches to the outside to release the battery.
Agregar Comentario
Pull the battery out by lifting the battery cover away from the laptop. Pull the battery out by lifting the battery cover away from the laptop.
  • Pull the battery out by lifting the battery cover away from the laptop.
Agregar Comentario
Flip the computer over and insert the plastic opening tool under the plastic strip at the top of the keyboard. Pry the top plastic strip from the top of the keyboard. Peel the strip completely away from the keyboard.
  • Flip the computer over and insert the plastic opening tool under the plastic strip at the top of the keyboard.
  • Pry the top plastic strip from the top of the keyboard.
  • Peel the strip completely away from the keyboard.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Using your Phillips #00, unscrew the two 4.80mm screws at the top of the keyboard. Using your Phillips #00, unscrew the two 4.80mm screws at the top of the keyboard.
  • Using your Phillips #00, unscrew the two 4.80mm screws at the top of the keyboard.
Agregar Comentario
When removing the keyboard, be careful not to rip the ribbon cable connecting the keyboard to the computer, to avoid damaging it. Flip the keyboard up from the bottom in order to see the two ribbons connecting it to the motherboard.
  • When removing the keyboard, be careful not to rip the ribbon cable connecting the keyboard to the computer, to avoid damaging it.
  • Flip the keyboard up from the bottom in order to see the two ribbons connecting it to the motherboard.
Agregar Comentario
Using the plastic opening tools, pop out the ribbon cable from the rest of the computer.
  • Using the plastic opening tools, pop out the ribbon cable from the rest of the computer.
Agregar Comentario
Using the plastic opening tools, pop out the second ribbon cable from the rest of the computer.
  • Using the plastic opening tools, pop out the second ribbon cable from the rest of the computer.
Agregar Comentario
Completely remove the keyboard from the laptop by lifting up the part closest to the screen, and then gently pulling out the bottom half. Keep the keyboard safe by storing it on a flat, non-metallic surface until needed.
  • Completely remove the keyboard from the laptop by lifting up the part closest to the screen, and then gently pulling out the bottom half.
  • Keep the keyboard safe by storing it on a flat, non-metallic surface until needed.
Agregar Comentario
Conclusión
Ian Washburne
Miembro Desde 11/01/13
45 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 17-21, Forte Winter 2013 Miembro de Cal Poly, Team 17-21, Forte Winter 2013
CPSU-FORTE-W13S17G21
5 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 2
Últimos 30 Días: 7
Todo El Tiempo: 1,153
