Introducción
The front panel may need to be replaced if your track pad is not working. However, this guide is very important as it can be found in nearly every other guide. Removing the front panel is how you get to most of the other parts of the device.
Partes
No se requieren partes.
Slide both of the latches to the outside to release the battery. Slide both of the latches to the outside to release the battery.
  • Slide both of the latches to the outside to release the battery.
Agregar Comentario
Pull the battery out by lifting the battery cover away from the laptop. Pull the battery out by lifting the battery cover away from the laptop.
  • Pull the battery out by lifting the battery cover away from the laptop.
Agregar Comentario
Flip the computer over and insert the plastic opening tool under the plastic strip at the top of the keyboard. Pry the top plastic strip from the top of the keyboard. Peel the strip completely away from the keyboard.
  • Flip the computer over and insert the plastic opening tool under the plastic strip at the top of the keyboard.
  • Pry the top plastic strip from the top of the keyboard.
  • Peel the strip completely away from the keyboard.
Agregar Comentario
Using your Phillips #00, unscrew the two 4.80mm screws at the top of the keyboard. Using your Phillips #00, unscrew the two 4.80mm screws at the top of the keyboard.
  • Using your Phillips #00, unscrew the two 4.80mm screws at the top of the keyboard.
Agregar Comentario
When removing the keyboard, be careful not to rip the ribbon cable connecting the keyboard to the computer, to avoid damaging it. Flip the keyboard up from the bottom in order to see the two ribbons connecting it to the motherboard.
  • When removing the keyboard, be careful not to rip the ribbon cable connecting the keyboard to the computer, to avoid damaging it.
  • Flip the keyboard up from the bottom in order to see the two ribbons connecting it to the motherboard.
Agregar Comentario
Using the plastic opening tools, pop out the ribbon cable from the rest of the computer.
  • Using the plastic opening tools, pop out the ribbon cable from the rest of the computer.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Using the plastic opening tools, pop out the second ribbon cable from the rest of the computer.
  • Using the plastic opening tools, pop out the second ribbon cable from the rest of the computer.
Agregar Comentario
Completely remove the keyboard from the laptop by lifting up the part closest to the screen, and then gently pulling out the bottom half. Keep the keyboard safe by storing it on a flat, non-metallic surface until needed.
  • Completely remove the keyboard from the laptop by lifting up the part closest to the screen, and then gently pulling out the bottom half.
  • Keep the keyboard safe by storing it on a flat, non-metallic surface until needed.
Agregar Comentario
Locate the four silver screws on the front panel. Using the Phillips #0, unscrew to remove all four 2.95mm silver screws.
  • Locate the four silver screws on the front panel.
  • Using the Phillips #0, unscrew to remove all four 2.95mm silver screws.
Agregar Comentario
Flip the laptop over and locate all seven screws on the bottom of the laptop. Unscrew all seven Philips#00 7.70mm screws.
  • Flip the laptop over and locate all seven screws on the bottom of the laptop.
  • Unscrew all seven Philips#00 7.70mm screws.
Agregar Comentario
Locate and unscrew the three silver Philips #00 2.85mm screws inside the battery compartment. Locate and unscrew the five black Philips #00 3.25mm screws inside the battery compartment.
  • Locate and unscrew the three silver Philips #00 2.85mm screws inside the battery compartment.
  • Locate and unscrew the five black Philips #00 3.25mm screws inside the battery compartment.
Agregar Comentario
Rotate the laptop so the back faces you. Locate the two black Philips #00 7.65 screws, one by each hinge, and remove.
  • Rotate the laptop so the back faces you.
  • Locate the two black Philips #00 7.65 screws, one by each hinge, and remove.
Agregar Comentario
Use the plastic opening tool to pry the top panel up from the base of the computer. Slowly work your way around the computer with the plastic removing tool to make it easier to lift the top panel away from the base. Carefully lift the top panel no more than six inches, as there are ribbon cables connecting the two pieces.
  • Use the plastic opening tool to pry the top panel up from the base of the computer.
  • Slowly work your way around the computer with the plastic removing tool to make it easier to lift the top panel away from the base.
  • Carefully lift the top panel no more than six inches, as there are ribbon cables connecting the two pieces.
  • Disconnect ribbons, and slowly lift the top panel up, away from the base.
Agregar Comentario
Locate the ribbon cable from the motherboard. Using plastic removing tools, pop the ribbon base from the motherboard.
  • Locate the ribbon cable from the motherboard.
  • Using plastic removing tools, pop the ribbon base from the motherboard.
Agregar Comentario
Locate the two plugs from the motherboard. Using plastic opening tools, remove each plug from the motherboard.
  • Locate the two plugs from the motherboard.
  • Using plastic opening tools, remove each plug from the motherboard.
Agregar Comentario
Locate the ribbon cable partially hidden under the front panel. Using plastic opening tools, pop out the ribbon cable from the motherboard.
  • Locate the ribbon cable partially hidden under the front panel.
  • Using plastic opening tools, pop out the ribbon cable from the motherboard.
Agregar Comentario
Make sure that all wires have been disconnected before proceeding to avoid damaging components.
  • Make sure that all wires have been disconnected before proceeding to avoid damaging components.
  • Slowly lift the top panel away from the base of the computer.
  • Place the top panel away from the computer and keep in a flat non-metallic surface until needed.
Agregar Comentario
Conclusión
Ian Washburne
Miembro Desde 11/01/13
45 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 17-21, Forte Winter 2013 Miembro de Cal Poly, Team 17-21, Forte Winter 2013
CPSU-FORTE-W13S17G21
5 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 751
