Partes
No se requieren partes.
Remove the 5.75 mm screw from the cover panel. Turn the laptop over with the screen facing down.
  • Remove the 5.75 mm screw from the cover panel.
  • Turn the laptop over with the screen facing down.
Agregar Comentario
Lift up the cover panel using a plastic opening tool.
  • Lift up the cover panel using a plastic opening tool.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the 5.64 mm screw from the bottom of the crossing bar. Remove the crossing bar.
  • Remove the 5.64 mm screw from the bottom of the crossing bar.
  • Remove the crossing bar.
Agregar Comentario
Use a plastic opening tool to disconnect the black and white antenna cable's connectors from the Wi-Fi card. Note that the black wire is connected to the port that is labeled main.
  • Use a plastic opening tool to disconnect the black and white antenna cable's connectors from the Wi-Fi card.
    • Note that the black wire is connected to the port that is labeled main.
Agregar Comentario
Use fingers to push the clips away from memory card. Use fingers to push the clips away from memory card.
  • Use fingers to push the clips away from memory card.
Agregar Comentario
Use fingers to remove the Wi-Fi card.
  • Use fingers to remove the Wi-Fi card.
Agregar Comentario
Conclusión
3 personas más completaron esta guía.
Garrett Gudgel
Miembro Desde 05/10/10
714 Reputación
13 Guías creadas
Equipo
Cal Poly, Team 4-43, Amido Fall 2010 Miembro de Cal Poly, Team 4-43, Amido Fall 2010
CPSU-AMIDO-F10S4G43
5 Miembros
13 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 3,033
