Introducción
This guide tells you how to replace the current hard drive in the laptop with one of better storage or functionality.
Partes
No se requieren partes.
Look at the bottom of the laptop. Using a Phillips screwdriver, unscrew and remove the screw labeled F4, located on the cover of the hard drive. The hard drive is located next to the CD drive.
  • Look at the bottom of the laptop. Using a Phillips screwdriver, unscrew and remove the screw labeled F4, located on the cover of the hard drive.
  • The hard drive is located next to the CD drive.
Agregar Comentario
Placing your finger on the raised grip, push up on the hard drive cover. This will remove  the hard drive cover from the laptop.
  • Placing your finger on the raised grip, push up on the hard drive cover. This will remove the hard drive cover from the laptop.
Agregar Comentario
Using a Phillips screwdriver, unscrew and remove the screw surrounded by the white plastic. Using a Phillips screwdriver, unscrew and remove the screw surrounded by the white plastic.
  • Using a Phillips screwdriver, unscrew and remove the screw surrounded by the white plastic.
Agregar Comentario
Pull the white plastic out toward you. This should remove the hard drive tray from the laptop.
  • Pull the white plastic out toward you. This should remove the hard drive tray from the laptop.
  • This laptop does not have a hard drive, so the tray is empty. On your computer, the hard drive should be in the tray.
Agregar Comentario
Conclusión
Hannah
Miembro Desde 24/06/10
209 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 3-5, Johann Summer 2010 Miembro de Cal Poly, Team 3-5, Johann Summer 2010
CPSU-JOHANN-R10S3G5
4 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 11
Todo El Tiempo: 3,581
