Saltar al contenido principal
Toshiba SD-K740 Front Panel Replacement
Qué necesitas
  1. Toshiba SD-K740 Front Panel Replacement, Top Panel: paso 1, imagen 1 de 1
    • Unplug the DVD player before beginning.
    • Remove the three 7.7 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba SD-K740 Front Panel Replacement: paso 2, imagen 1 de 2 Toshiba SD-K740 Front Panel Replacement: paso 2, imagen 2 de 2
    • Turn the DVD player on its side.
    • Remove the 7.7 mm screw.
    • Flip the DVD player onto its other side.
  3. Toshiba SD-K740 Front Panel Replacement: paso 3, imagen 1 de 1
    • Flip the DVD player over onto its front face.
    • Remove the back panel by lifting up and pulling it towards yourself.
  4. Toshiba SD-K740 Front Panel Replacement, Front Panel: paso 4, imagen 1 de 1
    • Flip the DVD player so its top is sitting on your working surface.
    • Lift and push away the two tabs located in the middle of the player.
    • The front panel will not detach during this step, so do not force it.
  5. Toshiba SD-K740 Front Panel Replacement: paso 5, imagen 1 de 1
    • Flip the DVD player on its side.
    • Lift and slide forward the single tab on the side.
  6. Toshiba SD-K740 Front Panel Replacement: paso 6, imagen 1 de 2 Toshiba SD-K740 Front Panel Replacement: paso 6, imagen 2 de 2
    • Grasp the front panel and pull forward to your right to remove it.
Conclusión
Joe Murphy
Miembro Desde 01/20/11
542 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 1-16, Amido Winter 2011 Miembro de Cal Poly, Team 1-16, Amido Winter 2011
CPSU-AMIDO-W11S1G16
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 491
