Introducción
This guide gives instructions on how to remove the disc drive of the Toshiba SD-K740 DVD player.
Partes
No se requieren partes.
Make sure the DVD player is unplugged before beginning.
  • Make sure the DVD player is unplugged before beginning.
  • Remove the three .303 inch screws from the back panel using a #0 Phillips head screwdriver.
Agregar Comentario
Turn the DVD player on its side. Remove the .303 inch screw.
  • Turn the DVD player on its side.
  • Remove the .303 inch screw.
  • Now flip the DVD player onto its other side.
  • Remove the .303 inch screw from this side.
Agregar Comentario
Flip the DVD player over onto it's front face.
  • Flip the DVD player over onto it's front face.
  • Remove the back panel by lifting up and pulling it towards yourself.
Agregar Comentario
Flip the DVD player so its top is sitting on your working surface.
  • Flip the DVD player so its top is sitting on your working surface.
  • Lift and push away each of the two tabs located in the middle of the player.
  • The front panel will not come off during this step, so do not force it.
Agregar Comentario
Flip the DVD player on its side.
  • Flip the DVD player on its side.
  • Lift and slide forward a single tab on the side.
Agregar Comentario
Grasp the front panel and pull forward and to your right to remove. Grasp the front panel and pull forward and to your right to remove.
  • Grasp the front panel and pull forward and to your right to remove.
Agregar Comentario
Remove the first of three ribbon cables on left hand side of disc drive by pulling vertically. Remove the first of three ribbon cables on left hand side of disc drive by pulling vertically.
  • Remove the first of three ribbon cables on left hand side of disc drive by pulling vertically.
Agregar Comentario
Remove the second of three ribbon cables on left hand side of disc drive by pulling vertically. Remove the second of three ribbon cables on left hand side of disc drive by pulling vertically.
  • Remove the second of three ribbon cables on left hand side of disc drive by pulling vertically.
Agregar Comentario
Remove the third of three ribbon cables on left hand side of disc drive by pulling vertically. Remove the third of three ribbon cables on left hand side of disc drive by pulling vertically.
  • Remove the third of three ribbon cables on left hand side of disc drive by pulling vertically.
Agregar Comentario
Remove the four screws holding the disc drive in place using a #0 Phillips screwdriver.
  • Remove the four screws holding the disc drive in place using a #0 Phillips screwdriver.
Agregar Comentario
Lift disc drive vertically to remove.
  • Lift disc drive vertically to remove.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Joe Murphy
Miembro Desde 20/01/11
542 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 1-16, Amido Winter 2011 Miembro de Cal Poly, Team 1-16, Amido Winter 2011
CPSU-AMIDO-W11S1G16
4 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 3
Últimos 30 Días: 17
Todo El Tiempo: 1,929
