Introducción
Use this guide to remove or replace the Motherboard in the TomTom XL.
Slip a small plastic opening tool underneath the screen bezel, gently sliding it around the inside edge.
  • Slip a small plastic opening tool underneath the screen bezel, gently sliding it around the inside edge.
  • Starting at the corners, carefully pry up the screen bezel.
Agregar Comentario
Remove the four Phillips #00 screws around the edge of the screen.
  • Remove the four Phillips #00 screws around the edge of the screen.
Agregar Comentario
Slide a small plastic opening tool under the top portion of the metal frame and gently lift it up. Slide the plastic opening tool around the inner edge of the metal frame until it feels loose. It may take some time to release the frame from the housing. Some force may be necessary—but be careful not to bend the frame's fragile interior bracket.
  • Slide a small plastic opening tool under the top portion of the metal frame and gently lift it up.
  • Slide the plastic opening tool around the inner edge of the metal frame until it feels loose.
    • It may take some time to release the frame from the housing. Some force may be necessary—but be careful not to bend the frame's fragile interior bracket.
  • Remove the frame from the housing.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Lifting from the upper edge of the screen, tilt the screen away from the device. Tilt the screen slowly. Flipping the screen up too quickly may damage the display cable.
  • Lifting from the upper edge of the screen, tilt the screen away from the device.
  • Tilt the screen slowly. Flipping the screen up too quickly may damage the display cable.
Agregar Comentario
Remove the three Phillips #00 screws connecting the motherboard to the plastic housing: Two Phillips #00 screws are located at the bottom of the first picture.
  • Remove the three Phillips #00 screws connecting the motherboard to the plastic housing:
    • Two Phillips #00 screws are located at the bottom of the first picture.
    • The third screw is hidden under the orange ribbon cable, near the screen.
      • You may have to carefully lift the screen in order to reach this screw.
Agregar Comentario
Flip the screen and motherboard over. Gripping the plastic casing, disconnect the battery cable connector from the motherboard.
  • Flip the screen and motherboard over.
  • Gripping the plastic casing, disconnect the battery cable connector from the motherboard.
  • Disconnect the speaker cable connector from the motherboard.
  • Remove the motherboard and screen from the housing.
Agregar Comentario
Using your thumbs or the flat end of a spudger, push back the white tabs on the display cable ZIF connector. Gently pull the orange display cable out of the ZIF connector. The display cable should slide out easily, but it may still have some adhesive on the underside. If you feel resistance, gently lift up on the ribbon cable while pulling it from the socket.
  • Using your thumbs or the flat end of a spudger, push back the white tabs on the display cable ZIF connector.
  • Gently pull the orange display cable out of the ZIF connector.
    • The display cable should slide out easily, but it may still have some adhesive on the underside. If you feel resistance, gently lift up on the ribbon cable while pulling it from the socket.
Agregar Comentario
Remove the motherboard from the device.
  • Remove the motherboard from the device.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Sean Higginson
Miembro Desde 21/04/10
145 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 33-84, Johann Spring 2010 Miembro de Cal Poly, Team 33-84, Johann Spring 2010
CPSU-JOHANN-S10S33G84
4 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 6
Últimos 30 Días: 22
Todo El Tiempo: 6,728
