Introducción
The front cover can get chipped or scratched. In this case it should be replaced.
Use a T-9 Torx screwdriver to unscrew the four screws on the back cover.
  • Use a T-9 Torx screwdriver to unscrew the four screws on the back cover.
Agregar Comentario
Using the spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device. Using the spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device.
  • Using the spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device.
Agregar Comentario
Carefully pull the back cover apart from the front cover. Be careful not to pull too hard because there are two sets of wires connecting the device.
  • Carefully pull the back cover apart from the front cover. Be careful not to pull too hard because there are two sets of wires connecting the device.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Once the two covers are separated, use the tweezers, or even your fingers, to gently disconnect the two sets of wires that are connected to the motherboard from the back cover. You may have to wiggle the wires a little bit to get them to disconnect.
  • Once the two covers are separated, use the tweezers, or even your fingers, to gently disconnect the two sets of wires that are connected to the motherboard from the back cover. You may have to wiggle the wires a little bit to get them to disconnect.
Agregar Comentario
Next, you must remove the motherboard from the front screen.
  • Next, you must remove the motherboard from the front screen.
  • Use a Torx T-7 screwdriver to unscrew the two screws.
Agregar Comentario
Before you can seperate the motherboard from the front cover, you must disconnect the wire connecting the two. To do so, you must use the back end of the spudger to push out the two white tabs connected to the wire, that holds the motherboard and front cover together.
  • Before you can seperate the motherboard from the front cover, you must disconnect the wire connecting the two.
  • To do so, you must use the back end of the spudger to push out the two white tabs connected to the wire, that holds the motherboard and front cover together.
Agregar Comentario
Once separated, use the spudger to pry around the edges of the outer casing.
  • Once separated, use the spudger to pry around the edges of the outer casing.
Agregar Comentario
Apply pressure with thumbs to remove screen from inner casing. The screen and front cover are now disconnected.
  • Apply pressure with thumbs to remove screen from inner casing.
  • The screen and front cover are now disconnected.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Trevor Foster
Miembro Desde 18/04/10
142 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 7-7, Maness Spring 2010 Miembro de Cal Poly, Team 7-7, Maness Spring 2010
CPSU-MANESS-S10S7G7
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 8
Todo El Tiempo: 4,080
