Saltar al contenido principal
Texas Instruments TI-83 Plus Individual Keys Replacement
Qué necesitas
  1. Texas Instruments TI-83 Plus Individual Keys Replacement, Backup Battery: paso 1, imagen 1 de 2 Texas Instruments TI-83 Plus Individual Keys Replacement, Backup Battery: paso 1, imagen 2 de 2
    • Remove the battery cover.
    • Remove the AAA batteries from the calculator.
  2. Texas Instruments TI-83 Plus Individual Keys Replacement: paso 2, imagen 1 de 1
    • Remove the 5mm Philips #00 screw holding backup battery cover.
    • Remove the backup battery cover.
  3. Texas Instruments TI-83 Plus Individual Keys Replacement: paso 3, imagen 1 de 1
    • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
    • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
  4. Texas Instruments TI-83 Plus Individual Keys Replacement, Back Case: paso 4, imagen 1 de 1
    • Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
  5. Texas Instruments TI-83 Plus Individual Keys Replacement: paso 5, imagen 1 de 2 Texas Instruments TI-83 Plus Individual Keys Replacement: paso 5, imagen 2 de 2
    • Pry back case off. Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart.
  6. Texas Instruments TI-83 Plus Individual Keys Replacement, Motherboard & Screen: paso 6, imagen 1 de 2 Texas Instruments TI-83 Plus Individual Keys Replacement, Motherboard & Screen: paso 6, imagen 2 de 2
    • Keep the screen face-down during this step. Only the motherboard is attached to the face-plate and the screen may fall out.
    • Remove the eight (8) 5mm Philips #00 screws on the motherboard.
  7. Texas Instruments TI-83 Plus Individual Keys Replacement: paso 7, imagen 1 de 2 Texas Instruments TI-83 Plus Individual Keys Replacement: paso 7, imagen 2 de 2
    • Carefully remove the motherboard and screen. Grab the board by its side with one hand and the screen with the other. Carefully lift the two parts up.
    • Keep the face-plate face-down to prevent the keys from falling out.
  8. Texas Instruments TI-83 Plus Individual Keys Replacement, Keyboard Mat: paso 8, imagen 1 de 2 Texas Instruments TI-83 Plus Individual Keys Replacement, Keyboard Mat: paso 8, imagen 2 de 2
    • Remove light gray rubber keyboard mat.
    • Keep your calculator face down to ensure the individual keys do not fall out.
  9. Texas Instruments TI-83 Plus Individual Keys Replacement: paso 9, imagen 1 de 1
    • Clean the contacts on the keyboard with a soft cloth.
  10. Texas Instruments TI-83 Plus Individual Keys Replacement, Individual Keys: paso 10, imagen 1 de 2 Texas Instruments TI-83 Plus Individual Keys Replacement, Individual Keys: paso 10, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to remove one key at a time.
    • Be sure to keep them organized if you are taking out multiple keys.
Conclusión
2 personas más completaron esta guía.
Jared
Miembro Desde 10/02/12
151 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 18-37, Regan Fall 2012 Miembro de Cal Poly, Team 18-37, Regan Fall 2012
CPSU-REGAN-F12S18G37
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 21
Todo El Tiempo: 4,682
