Introducción
If your back case is cracked or broken this guide will show you how it is removed and replaced.
Remove the battery cover. Remove the AAA batteries from the calculator.
  • Remove the battery cover.
  • Remove the AAA batteries from the calculator.
Agregar Comentario
Remove the 5mm Philips #00 screw holding backup battery cover.
  • Remove the 5mm Philips #00 screw holding backup battery cover.
  • Remove the backup battery cover.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Use plastic opening tool to remove the backup battery.  Place the tool in the small cut-out next to the battery and pry the battery out.
  • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
  • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
Agregar Comentario
Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
  • Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
Agregar Comentario
Pry back case off.  Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart. Pry back case off.  Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart.
  • Pry back case off. Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart.
Agregar Comentario
Conclusión
4 personas más completaron esta guía.
Jared
Miembro Desde 02/10/12
76 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 18-37, Regan Fall 2012 Miembro de Cal Poly, Team 18-37, Regan Fall 2012
CPSU-REGAN-F12S18G37
5 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 9
Últimos 30 Días: 52
Todo El Tiempo: 6,653
