Introducción
The boiler heat the water to the needed temperature for both the steam wand and portafilter. If your machine isn't heating up, one possible cause is a failed heating element inside the boiler. This guide will show you how to test for this.
Partes
No se requieren partes.
Remove the 6 Phillips #1 screws from the back panel. Remove the back panel.
  • Remove the 6 Phillips #1 screws from the back panel.
  • Remove the back panel.
Agregar Comentario
Make sure the machine is turned off and unplugged.
  • Make sure the machine is turned off and unplugged.
  • Set your voltmeter in continuity mode and place the leads on the two 90 degree prongs on the boiler's heating element.
  • It does not matter which lead touches which prong as you're just testing for a break, or "open" in the heating element circuit.'''
  • If the voltmeter shows 0, or "open", then there is an issue with the heating element's continuity and it needs to be replaced.
  • If given a reading, then your heating element is fine.
Agregar Comentario
In the water reservoir, place mixture of de-calcifying agent and water as directed on the product label.
  • In the water reservoir, place mixture of de-calcifying agent and water as directed on the product label.
  • Place a cup, to catch fluid, underneath the portafilter.
  • Run Barista, as if making coffee, for the amount of time directed by the de-calcifying product.
    • See the links section of the device page for further directions.
Agregar Comentario
Conclusión
8 personas más completaron esta guía.
Brian McMurray
Miembro Desde 31/01/11
189 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 4-42, Regan Winter 2011 Miembro de Cal Poly, Team 4-42, Regan Winter 2011
CPSU-REGAN-W11S4G42
4 Miembros
5 Guías creadas
I did this a few months ago and the boiler was full of rusty gunk. This guide sure did help me out.
oguitar200 - Contestar
the same here - it was disgusting... was afraid to have damaged it while cleaning it. tested it yesterday already... just going through all the steps to validate function of the units.
Martin Zeitler -
hi ! we have Starbucks Barisa Milano. some how it didnt want switch on! my husband wanted to have a look but we cant open. do you gave any guidence?
Zorigoo Purev - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 12
Últimos 30 Días: 61
Todo El Tiempo: 16,022
