Saltar al contenido principal
Technique - Test the Battery
Qué necesitas
  1. Technique - Test the Battery, Technique - Test the Battery: paso 1, imagen 1 de 3 Technique - Test the Battery, Technique - Test the Battery: paso 1, imagen 2 de 3 Technique - Test the Battery, Technique - Test the Battery: paso 1, imagen 3 de 3
    • Remove back cover by applying pressure and sliding up towards the top of the phone.
  2. Technique - Test the Battery: paso 2, imagen 1 de 2 Technique - Test the Battery: paso 2, imagen 2 de 2
    • Remove the battery by lifting from slot on the right hand side.
  3. Technique - Test the Battery: paso 3, imagen 1 de 2 Technique - Test the Battery: paso 3, imagen 2 de 2
    • Use Multimeter to test the voltage of the battery.
    • Put the black lead into ground slot of multimeter and the red lead into the V(ohm)mA slot.
    • Place the red and black leads to the two outside metal plate, each on opposite sides, on the battery as shown.
    • Check that the voltage displayed on the multimeter matches closely to the voltage defined on the battery. Normally 3.7 V.
Conclusión
Una persona más ha completado esta guía.
Melinda Phan
Miembro Desde 04/17/11
438 Reputación
9 Guías creadas
Equipo
Cal Poly, Team 9-64, Walters Spring 2011 Miembro de Cal Poly, Team 9-64, Walters Spring 2011
CPSU-WALTERS-S11S9G64
5 Miembros
18 Guías creadas
2 comentarios
Hello one the question was tablet not telephone and it's really vague how you guys explain these things you need to go to work on your site
Roger Slater - Contestar
yes,not tablet with battery removal difficult
paulbeames7 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 33
Todo El Tiempo: 10,155
