Saltar al contenido principal
Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement
Qué necesitas
  1. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement, Back Cover: paso 1, imagen 1 de 1
    • Remove the four Torx T5 screws from the back panel.
  2. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: paso 2, imagen 1 de 1
    • Wedge a spudger in between the front and back panel.
    • Apply leverage downwards to the spudger in order to remove the back panel.
  3. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement, Battery: paso 3, imagen 1 de 1
    • Slide the battery out from under the brown wire-tape.
    • Be careful of the wires still connected to the other end of the battery. Do not pull or damage may occur.
  4. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Slowly pull the white plug from its receptor. Grasp its sides firmly with a pair of tweezers and gently wiggle from side to side.
  5. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement, Motherboard: paso 5, imagen 1 de 1
    • Unscrew the 2 Philips #00 screws on each end of the motherboard.
  6. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: paso 6, imagen 1 de 1
    Comprar
    • Pull off the black memory card slot piece with tweezers.
  7. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: paso 7, imagen 1 de 1
    • Unscrew the 2 Philips #00 screws on each side of the charging port.
  8. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: paso 8, imagen 1 de 2 Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: paso 8, imagen 2 de 2
    • Disconnect 2 brown wire-tape ends from each end of the motherboard. Gently pull straight out with tweezers.
  9. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: paso 9, imagen 1 de 1
    • Pull the motherboard and screen component diagonally up and left away from the auxiliary port entrance to remove.
    • Glue connecting the auxiliary port to the casing may make it difficult to remove. Gently apply force as needed.
  10. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: paso 10, imagen 1 de 1
    • Disconnect the 2 brown wire-tape ends from the left side of the battery slot on the motherboard using tweezers.
  11. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: paso 11, imagen 1 de 3 Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: paso 11, imagen 2 de 3 Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: paso 11, imagen 3 de 3
    • Disconnect the large brown wire-tape from the motherboard.
    • Peel the black tape back from the wire-tape using tweezers.
    • Lift the black, hinged, plastic lock with tweezers to release the wire-tape.
    • The screen and motherboard components can now be separated from each other.
  12. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement, Touchscreen/Display: paso 12, imagen 1 de 1
    • Unscrew the 2 Philips #00 screws from the bottom edge of the screen component.
  13. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: paso 13, imagen 1 de 1
    • Take off the brown wire-tape from the small circuit board component.
    • Lift up so that the black plastic hinge piece swings open and the tape can be removed.
  14. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: paso 14, imagen 1 de 3 Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: paso 14, imagen 2 de 3 Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: paso 14, imagen 3 de 3
    • Warning: If you are too rough with the screwdriver, you can permanently damage the display.
    • Use a Slot SL1.5 screwdriver to pry the touchscreen shell from the display component using the 4 slots around the entire component
Conclusión
Daniel Wiseman
Miembro Desde 01/20/12
133 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 10-33, Amido Winter 2012 Miembro de Cal Poly, Team 10-33, Amido Winter 2012
CPSU-AMIDO-W12S10G33
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 21
Todo El Tiempo: 917
