Saltar al contenido principal
Tapwave T2907US Zodiac 2 Directional Pad Replacement
Qué necesitas
  1. Tapwave T2907US Zodiac 2 Directional Pad Replacement, Back Cover: paso 1, imagen 1 de 1
    • Remove the four Torx T5 screws from the back panel.
  2. Tapwave T2907US Zodiac 2 Directional Pad Replacement: paso 2, imagen 1 de 1
    • Wedge a spudger in between the front and back panel.
    • Apply leverage downwards to the spudger in order to remove the back panel.
  3. Tapwave T2907US Zodiac 2 Directional Pad Replacement, Battery: paso 3, imagen 1 de 1
    • Slide the battery out from under the brown wire-tape.
    • Be careful of the wires still connected to the other end of the battery. Do not pull or damage may occur.
  4. Tapwave T2907US Zodiac 2 Directional Pad Replacement: paso 4, imagen 1 de 1
    • Slowly pull the white plug from its receptor. Grasp its sides firmly with a pair of tweezers and gently wiggle from side to side.
  5. Tapwave T2907US Zodiac 2 Directional Pad Replacement, Directional Pad: paso 5, imagen 1 de 1
    • Unscrew the 2 Philips #00 screws on each end of the motherboard.
  6. Tapwave T2907US Zodiac 2 Directional Pad Replacement: paso 6, imagen 1 de 1
    • Pull off the black memory card slot piece.
  7. Tapwave T2907US Zodiac 2 Directional Pad Replacement: paso 7, imagen 1 de 1
    • Unscrew the 2 Philips #00 screws on each side of the charging port.
  8. Tapwave T2907US Zodiac 2 Directional Pad Replacement: paso 8, imagen 1 de 2 Tapwave T2907US Zodiac 2 Directional Pad Replacement: paso 8, imagen 2 de 2
    • Disconnect 2 brown wire-tape ends from each end of the motherboard. Gently pull straight out with tweezers.
  9. Tapwave T2907US Zodiac 2 Directional Pad Replacement: paso 9, imagen 1 de 1
    • Grasp the upper left edge of the motherboard and slide diagonally up and left away from the auxiliary port entrance.
    • Glue connecting the port to the casing may make it difficult to remove. Gently apply force as needed.
  10. Tapwave T2907US Zodiac 2 Directional Pad Replacement: paso 10, imagen 1 de 1
    • Unscrew the 2 silver Philips #00 screws from both sides of the directional pad component on the front casing.
  11. Tapwave T2907US Zodiac 2 Directional Pad Replacement: paso 11, imagen 1 de 2 Tapwave T2907US Zodiac 2 Directional Pad Replacement: paso 11, imagen 2 de 2
    • Take out the 2 pieces of the directional pad with tweezers.
Conclusión
Una persona más ha completado esta guía.
Daniel Wiseman
Miembro Desde 01/20/12
133 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 10-33, Amido Winter 2012 Miembro de Cal Poly, Team 10-33, Amido Winter 2012
CPSU-AMIDO-W12S10G33
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 630
