Introducción
Use this guide when the auxiliary port needs to be replaced.
Qué necesitas
Slide the battery out from under the brown wire-tape.
Be careful of the wires still connected to the other end of the battery. Do not pull or damage may occur.
Herramienta utilizada en este paso:Desoldering Pump$3.99
Remove the solder between the auxiliary port and the motherboard carefully with the desoldering pump.
Casi Terminas!
Conclusión
