Introducción
Removing the TRS-80 Color Computer's motherboard.
Partes
No se requieren partes.
Flip the computer over.
  • Flip the computer over.
  • Remove the two 24.1mm Phillips screws near the front of the case.
  • Remove the five 33.0 mm Phillips screws towards the back of the case.
Agregar Comentario
Carefully flip the computer right side up. Lift off the top half of the case.
  • Carefully flip the computer right side up.
  • Lift off the top half of the case.
Agregar Comentario
Near the motherboard, gently pull the keyboard ribbon cable until it becomes free. Lift the keyboard out of the case.
  • Near the motherboard, gently pull the keyboard ribbon cable until it becomes free.
  • Lift the keyboard out of the case.
Agregar Comentario
Remove the nine 15.24 mm Phillips screws securing the motherboard in place. When removing the spring door, make sure to keep the door closed. When removing the spring door, make sure to keep the door closed.
  • Remove the nine 15.24 mm Phillips screws securing the motherboard in place.
  • When removing the spring door, make sure to keep the door closed.
Agregar Comentario
Remove the 5 jumper cables from the motherboard. Once the jumper cables lift the motherboard up gently; it should lift out easily. Once the jumper cables lift the motherboard up gently; it should lift out easily.
  • Remove the 5 jumper cables from the motherboard.
  • Once the jumper cables lift the motherboard up gently; it should lift out easily.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Andrew
Miembro Desde 23/01/11
442 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 11-24, Maness Winter 2011 Miembro de Cal Poly, Team 11-24, Maness Winter 2011
CPSU-MANESS-W11S11G24
4 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 6
Últimos 30 Días: 16
Todo El Tiempo: 2,875
