Introducción
Replace a broken fuse on the TRS-80 Color Computer's power supply.
Flip the computer over.
  • Flip the computer over.
  • Remove the two 24.1mm Phillips screws near the front of the case.
  • Remove the five 33.0 mm Phillips screws towards the back of the case.
Agregar Comentario
Carefully flip the computer right side up. Lift off the top half of the case.
  • Carefully flip the computer right side up.
  • Lift off the top half of the case.
Agregar Comentario
Near the motherboard, gently pull the keyboard ribbon cable until it becomes free. Lift the keyboard out of the case.
  • Near the motherboard, gently pull the keyboard ribbon cable until it becomes free.
  • Lift the keyboard out of the case.
Agregar Comentario
Remove the nine 15.24 mm Phillips screws securing the motherboard in place. When removing the spring door, make sure to keep the door closed. When removing the spring door, make sure to keep the door closed.
  • Remove the nine 15.24 mm Phillips screws securing the motherboard in place.
  • When removing the spring door, make sure to keep the door closed.
Agregar Comentario
Remove the 5 jumper cables from the motherboard. Once the jumper cables lift the motherboard up gently; it should lift out easily. Once the jumper cables lift the motherboard up gently; it should lift out easily.
  • Remove the 5 jumper cables from the motherboard.
  • Once the jumper cables lift the motherboard up gently; it should lift out easily.
Agregar Comentario
Remove the two 40.6mm Philips screws securing the TRS-80 transformer. Remove the two 40.6mm Philips screws securing the TRS-80 transformer.
  • Remove the two 40.6mm Philips screws securing the TRS-80 transformer.
Agregar Comentario
Remove the power cable jumpers from the power supply. Remove the power cable jumpers from the power supply. Remove the power cable jumpers from the power supply.
  • Remove the power cable jumpers from the power supply.
Agregar Comentario
Gently peel back the protective film on the top of the transformer.
  • Gently peel back the protective film on the top of the transformer.
Agregar Comentario
Locate the two points the fuse is soldered into the circuit board. Using a soldering iron and soldering wick, desolder and remove the fuse. Place the new fuse into the location of the old one, and solder it in place.
  • Locate the two points the fuse is soldered into the circuit board.
  • Using a soldering iron and soldering wick, desolder and remove the fuse.
  • Place the new fuse into the location of the old one, and solder it in place.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team 11-24, Maness Winter 2011 Miembro de Cal Poly, Team 11-24, Maness Winter 2011
CPSU-MANESS-W11S11G24
4 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 4
Últimos 30 Días: 5
Todo El Tiempo: 2,039
