Introducción
This guide is useful if the SIM card of the phone needs to be replaced or removed.
Herramientas
No se requieren herramientas.
Partes
No se requieren partes.
To remove the battery cover, first turn the phone so that the keypad is face down. While holding the phone with one hand, place the thumb of the other hand at the top of the battery cover. Slide the battery cover toward the bottom of the phone to remove.
  • To remove the battery cover, first turn the phone so that the keypad is face down.
  • While holding the phone with one hand, place the thumb of the other hand at the top of the battery cover.
  • Slide the battery cover toward the bottom of the phone to remove.
Agregar Comentario
To remove the battery, first grab it using a finger on either side. Pull the battery upward, while securing the phone with your other hand.
  • To remove the battery, first grab it using a finger on either side.
  • Pull the battery upward, while securing the phone with your other hand.
  • Gently remove the battery and place it to the side of the phone.
Agregar Comentario
Open the SIM card door, located on the lower right part of the phone. Insert the SIM card into the door with the gold plating facing downward. Close the SIM card door by lightly pushing downward.
  • Open the SIM card door, located on the lower right part of the phone.
  • Insert the SIM card into the door with the gold plating facing downward.
  • Close the SIM card door by lightly pushing downward.
Agregar Comentario
Conclusión
Equipo
Clemson, Team 15-4, Benson Fall 2012 Miembro de Clemson, Team 15-4, Benson Fall 2012
CLEM-BENSON-F12S15G4
4 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 1
Todo El Tiempo: 302
