Saltar al contenido principal
Qué necesitas
Resumen del Video
Este desmontaje no es una guía de reparación. Para reparar tu Steam Deck, utiliza nuestros manuales de servicio .
    • Type 1: M1.6x9; plastic thread forming; 1.6 mm thread diameter; 0.64 mm thread pitch; 9 mm thread length; 2.8 mm head diameter; 0.6 mm head thickness
    • Type 2: M1.6x5; machine screw; 1.6 mm thread diameter; 0.35 mm thread pitch; 5 mm thread length; 2.8 mm head diameter; 0.5 mm head thickness
    • Type 3: M2x3.5; machine screw; 2 mm thread diameter; 0.4 mm thread pitch; 3.5 mm thread length; 5 mm head diameter; 0.9 mm head thickness
    • Type 4: M1.6x4.5; plastic thread forming; 1.6 mm thread diameter; 0.53 mm thread pitch; 4.5 mm thread length; 3.5 mm head diameter; 0.8 mm head thickness
    • Type 5: M1.6x3; machine screw; 1.6 mm thread diameter; 0.35 mm thread pitch; 3 mm thread length; 2.8 mm head diameter; 0.8 mm head thickness
    • Type 6: M2x2.2; machine screw; 2 mm thread diameter; 0.4 mm thread pitch; 2.2 mm thread length; 4.5 mm head diameter; 0.5 mm head thickness
    • Type 7: M1.6x4; plastic thread forming; 1.6 mm thread diameter; 0.53 mm thread pitch; 4 mm thread length; 3 mm head diameter; 0.8 mm head thickness
    • Type 8: M1.2x2; machine screw; 1.2 mm thread diameter; 0.25 mm thread pitch; 2 mm thread length; 2.2 mm head diameter; 0.4 mm head thickness
  1. Steam Deck Screw ID, Back cover: paso 2, imagen 1 de 2 Steam Deck Screw ID, Back cover: paso 2, imagen 2 de 2
    • Type 1: M1.6x9 plastic thread forming screw
    • Type 2: M1.6x5 machine screw
  2. Steam Deck Screw ID, Back cover removed: paso 3, imagen 1 de 2 Steam Deck Screw ID, Back cover removed: paso 3, imagen 2 de 2
    • Type 3: M2x3.5 machine screw
    • Type 4: M1.5x4.5 plastic thread forming screw
    • Type 5: M1.6x3 machine screw
  3. Steam Deck Screw ID, Motherboard shield removed: paso 4, imagen 1 de 2 Steam Deck Screw ID, Motherboard shield removed: paso 4, imagen 2 de 2
    • Type 6: M2x2.2 machine screw
  4. Steam Deck Screw ID, Trigger area: paso 5, imagen 1 de 2 Steam Deck Screw ID, Trigger area: paso 5, imagen 2 de 2
  5. Steam Deck Screw ID, Bumper area: paso 6, imagen 1 de 2 Steam Deck Screw ID, Bumper area: paso 6, imagen 2 de 2
  6. Steam Deck Screw ID, Trackpad area: paso 7, imagen 1 de 2 Steam Deck Screw ID, Trackpad area: paso 7, imagen 2 de 2
    • Type 7: M1.6x4 plastic thread forming screw
  7. Steam Deck Screw ID, Midframe: paso 8, imagen 1 de 2 Steam Deck Screw ID, Midframe: paso 8, imagen 2 de 2
  8. Steam Deck Screw ID, Under display: paso 9, imagen 1 de 2 Steam Deck Screw ID, Under display: paso 9, imagen 2 de 2
    • Type 8: M1.2x2 machine screw
Un comentario
Is there a way to convert these sizes to the ones used in the rest of the guides?
such as: M1.6x4= 4.7mm
Emojitsu Gaming - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 14
Ultimos 7 días: 105
Ultimos 30 días: 365
Todo El Tiempo: 2,878
