Introducción
The portafilter pressurizes the water through the coffee filter to produce the espresso. If the portafilter is dirty or malfunctioning it could result in weak coffee, or no coffee at all. This guide will help you disassemble, clean and reassemble your portafilter.
Partes
No se requieren partes.
Turn the portafilter handle to the left to remove it from the machine.
  • Turn the portafilter handle to the left to remove it from the machine.
  • Flip the portafilter over so the bottom with the 3 screws faces up.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Before beginning, make a small, neat "scribe" mark on both the bottom edge of the plastic basket and, right next to it, the top of the metal basket. This match-marks these two pieces. Unscrew and remove the 3 phillips-head screws. Lift off the plastic handle assembly, exposing the internal pressure system and two springs. Take note of the handle's orientation in relation to the metal piece as it will need to be re-attached in exactly the same position to function correctly.
  • Before beginning, make a small, neat "scribe" mark on both the bottom edge of the plastic basket and, right next to it, the top of the metal basket. This match-marks these two pieces. Unscrew and remove the 3 phillips-head screws.
  • Lift off the plastic handle assembly, exposing the internal pressure system and two springs. Take note of the handle's orientation in relation to the metal piece as it will need to be re-attached in exactly the same position to function correctly.
Agregar Comentario
Take note of the spring's placement, then carefully remove and set them aside. Clean the pressure assembly with a citrus-based cleaner and a brush, making sure to get under the hinged needle valve. Rinse well, then replace the springs.
  • Take note of the spring's placement, then carefully remove and set them aside.
  • Clean the pressure assembly with a citrus-based cleaner and a brush, making sure to get under the hinged needle valve. Rinse well, then replace the springs.
  • Reattach the handle assembly with the 3 phillips-head screws. If assembled correctly the handle should pivot slightly in relation to the metal portion, than spring back when released.
Agregar Comentario
Conclusión
7 personas más completaron esta guía.
David
Miembro Desde 28/01/11
547 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 4-42, Regan Winter 2011 Miembro de Cal Poly, Team 4-42, Regan Winter 2011
CPSU-REGAN-W11S4G42
4 Miembros
5 Guías creadas
Are there any pictures to show how to replace the gasket on the portafilter?
Scott - Contestar
any luck on replacing the gasket?
Erica Fisher -
Where can I purchase a portafilter for this? johnbrosnan2010@yahoo.com
johnbrosnan2005 - Contestar
i just did this and it worked. my problem was i kept thinking it wasnt working bc the water kept flowing out of the top and not going through the two holes into the cup. I figured out it needs the coffe grounds in there to actually work! thanks!
preceptgirl - Contestar
I am still having a problem with it Brewing you can tell it wants to but it won't come through sometimes a little bit will any suggestions.
Michelle Ward - Contestar
My experience is that either the portafilter or the filter on the machine head is clogged. I remove the machine head filter and scrub with a old tooth brush and wash and scrub the portable filter and holder. If this doesn’t work take the port filter apart and clean and scrub gently with a citric acid. Your supposed to use a descaler at least every 3 months. I also put the porta filter in water and let it soak and always run with straight water before and after usage and only use 2 tablespoons of coffee or less.
Barry Jones - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 7
Últimos 7 Días: 59
Últimos 30 Días: 208
Todo El Tiempo: 29,385
