Saltar al contenido principal
Starbucks Barista Steam Wand replacement or cleaning
Qué necesitas
  1. Starbucks Barista Steam Wand replacement or cleaning, steam wand: paso 1, imagen 1 de 1
    • Using a wrench, unscrew the hex nut and remove the steam wand.
    • Note: Do not lose the hex nut once it is unscrewed.
  2. Starbucks Barista Steam Wand replacement or cleaning: paso 2, imagen 1 de 2 Starbucks Barista Steam Wand replacement or cleaning: paso 2, imagen 2 de 2
    • Using a thin tool or item, such as a paper clip, poke around through the holes on both ends of the wand to remove any foreign material.
    • Place the steam wand in a de-calcifying solution as directed by product.
    • Reconnect the steam wand.
    • See the links section of the device page to purchase a new steam wand.
Conclusión
4 personas más completaron esta guía.
David
Miembro Desde 01/28/11
739 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 4-42, Regan Winter 2011 Miembro de Cal Poly, Team 4-42, Regan Winter 2011
CPSU-REGAN-W11S4G42
4 Miembros
5 Guías creadas
Un comentario
To replace steam-wand seals (in case of water leaking out from the center of the steam-wand): https://www.youtube.com/watch?v=fulyy9A9... , but note - for parts: https://philips.encompass.com/model/SAER... (worth going to amazon.de and entering the partnumbers into the search box: e.g. the o-rings for the needle-valve (996530013462)
R Cly - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 16
Todo El Tiempo: 15,854
